sequence size must match size of the row
9333
9
10-15-2020 09:08 PM
jayshukla
Hi, I am looking for some help on proper syntax in ArcGIS Pro/ Python 3. I am trying to read data from a feature class and write to another feature class. The attribute fields are different so I am reading from source and assigning it to output. I get this error at insertCursor.insertRow(newRow).
Appreciate any input.
def LoadData(fSource, fTarget):
# setup search cursorfields = ['*']  fldShape = "SHAPE@"# target field mapping fldCountry = 'Country'fldCommodity = "Product"constructionYear = "CNSTR_YEAR"try:      with arcpy.da.InsertCursor(fTarget, ['*']) as insertCursor:         with arcpy.da.SearchCursor(fSource, "*") as cursor:             for row in cursor:                 country = row[cursor.fields.index(fldCountry)]                 geometry = row[cursor.fields.index(fldShape)]                 commodity = row[cursor.fields.index(fldCommodity)]                 constructionYear = row[cursor.fields.index(constructionYear)]                                  newRow = [country, geometry, commodity, constructionYear]                  insertCursor.insertRow(newRow)  except Exception:         print(e.args[0])
RandyBurton
I need a bit more information on the calculation.  But I would add a field to a targetField list.  Then do the calculation just before the insert row.  The idea would be something like this, but the code is untested and needs modification to do the calculation.
fSource = '' # some source
fTarget = '' # the target
sourceFields = ['SHAPE@', 'Country', 'Product', 'CNSTR_YEAR']
targetFields = ['SHAPE@', 'Country', 'Product', 'CNSTR_YEAR', 'CalcField' ] # add calculated field
with with arcpy.da.InsertCursor(fTarget, targetFields) as insertCursor:
    with arcpy.da.SearchCursor(fSource, sourceFields) as cursor:
        for row in cursor:
            newRow = list(row) # get sourceField values
            x = 5+2 # some calculation
            newRow.append(x) # append calculation to end
            insertCursor.insertRow(newRow) # insert newRow to fTarget‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
The sequence size error is saying you are either trying to insert fewer or more items into a record than what the cursor is set up for.  Since you are using "*" for the fields, which by the way is a poor practice, I can't say for sure what is going wrong with the fields.
jayshukla
Thanks Joshua, I will try limiting the fields and see it helps.
DanPatterson
This would help with reading
/blogs/dan_patterson/2016/08/14/script-formatting
... sort of retired...
jayshukla
fields = ['*']
fldShape = "SHAPE@"
try:
  for row in cursor:
except Exception:
  print(e.args[0])
jayshukla
This looks better formatting, Thanks Dan for pointing this out.
RandyBurton
As Joshua Bixby‌ states, using a wildcard for the  fields is a bad idea.  In your case, you cannot be sure the order you are assembling the row matches the order the data was selected.  Also, for testing you should avoid a try/except block so the error messages will be clear and you can see what exceptions you may need to guard against.
Can we assume that the field names are identical (as well as field type and length)  between the source and target features?  If so, you might test the following with copies of your data:
fields = ['SHAPE@', 'Country', 'Product', 'CNSTR_YEAR'] # assuming same name used in both target/source
with with arcpy.da.InsertCursor(fTarget, fields) as insertCursor:
    with arcpy.da.SearchCursor(fSource, fields) as cursor:
        for row in cursor:
            insertCursor.insertRow(row)
jayshukla
Thanks Randy, Your code works great. I have one calculated value that doesn't exist in source data, how do I update that field in target using this construct.
RandyBurton
        for row in cursor:
jayshukla
Thanks Randy, Joshua for your help on this. this works like a charm, really appreciate your help on this.
