Sending Email from Python
10627
5
07-17-2012 06:27 AM
MarcCusumano
I am trying to get this to work:
import smtplib
from smtplib import SMTP_SSL as SMTP
import datetime
HOST = "xxxxxxxx.enterprise.xxxx.com"
PORT = 25
FROM = "xxxx.xxxxxxxx@xxxx.com"
TO = ["xxxx.xxxxxxxxx@xxxx.com"]
SUBJECT = "Test"
BODY = "Success"
BODY = BODY + "!"
smtp = smtplib.SMTP(HOST,PORT)
smtp.connect(HOST, PORT)
smtp.login("xxxxxx\xxxxx", "xxxxx")
smtp.ehlo()
smtp.sendmail(FROM,TO,body)
smtp.quit()
server.set_debuglevel(0)
But I keep getting the following error:
[Errno 10054] An existing connection was forcibly closed by the remote host
Can't see anything obvious I'm doing wrong. Any ideas? Thanks.
MarcCusumano
I got it, was actually quite simple:
import smtplib import datetime import logging  HOST = "mailhost.xxxx.com" PORT = 25 from_addr = r"xxxx.xxxxxxx@xxxx.com" to_addr = r"xxxx.xxxxxxx@xxxx.com" subj = "ArcServer Update Script" date = datetime.datetime.now().strftime( "%d/%m/%Y %H:%M" ) message_text = "Hello\nThis is a mail from your server\n\nBye\n" msg = "From: %s\nTo: %s\nSubject: %s\nDate: %s\n\n%s" % ( from_addr, to_addr, subj, date, message_text )  try:     test = "test"         smtp = smtplib.SMTP(HOST, PORT)     smtp.sendmail(from_addr,to_addr,msg + "%s" %(test))     smtp.quit()  except Exception as e:     print e     logging.error(": %s" %(e))
MathewCoyle
Honored Contributor
What version of python are you using? Also if you are using a domain log in you will need to send it raw, otherwise it may be interpreted as an escape.
r"xxxxxx\xxxxx"
I assume you are trying to run this on a schedule when you are not logged in? Is that why you need to specify specific log on credentials? More detail of what you are trying to accomplish and your environment would help. You would probably get a better response from a more general python forum like stack exchange since this really doesn't have anything to do with ArcGIS.
MikeHunter
I'm guessing that you either are trying to send from a company network that does not allow smtp usage, or you simply need to use tsl.  And use the email library, it handles all the ugly stuff for you.  Here's a function that does what you are trying to do.  All the args are strings except port (int), tls (boolean) and files (list of file names of attachments).  The code below is part of a larger program, so some of the imports may not be needed.
import os, time, sys
import smtplib
from socket import gaierror
from email.mime.text import MIMEText
from email.mime.base import MIMEBase
from email.mime.multipart import MIMEMultipart
from email.utils import COMMASPACE, formatdate
from email import Encoders
from mah.wxDialogs import ibox, getfiles, ibox
import utils
def sendMail(host, user, pwd, port, subject, tls,
                            sender, to, cc, files, text, pid='0'):
    '''main email sending function'''
##    print host, user, pwd, port, tls
    msg = MIMEMultipart()
    msg['From'] = strOrBust(sender)
    msg['To'] = strOrBust(COMMASPACE.join(to))
    if cc:
        msg['Cc'] = strOrBust(COMMASPACE.join(cc))
    msg['Date'] = strOrBust(formatdate(localtime=True))
    msg['Subject'] = strOrBust(subject)
    #encode body unicode to str before sending
    msg.attach(MIMEText(strOrBust(text)))
    for file in files:
        #run with basic bag of bits, using mimetypes to try to figure out
        #file type is not worth the effort, and is not as reliable
        part = MIMEBase('application', "octet-stream")
        part.set_payload( open(file,"rb").read() )
        Encoders.encode_base64(part)
        part.add_header('Content-Disposition', 'attachment; filename="%s"'
                       % os.path.basename(file))
        msg.attach(part)
    try:
        server = smtplib.SMTP(host, port)
    except (smtplib.SMTPException, gaierror), error:
        mailer.sb.SetStatusText('Failed to send email')
        ibox(str(error) + '  Cannot connect to Server!','Failed!')
        return
    # Optional, but it gives you a nice view of the conversation
##    server.set_debuglevel(1)
    server.ehlo()
    if tls:
        server.starttls()
    server.ehlo()
    if user:
        server.login(user, pwd)
    #sendmail doesn't care about to and cc, so add them together
    #then uniqify
    toall = to + cc
    toall = uniqify(toall)
    try:
        server.sendmail(sender, toall, msg.as_string())
        if mailer:
            mailer.sb.SetStatusText('Message ' + pid +
                                        ' was successfully sent')
    except smtplib.SMTPException, error:
        if mailer:
            ibox(str(error),'Failed!')
    server.close()
    return
def strOrBust(obj, encoding='utf-8'):
    '''converts unicode objects or other objects to str or returns original
        encoded to enncoding'''
    if isinstance(obj, basestring):
        if not isinstance(obj, str):
            obj = obj.encode(encoding, 'ignore')
        else:
            obj = obj.encode(encoding)
    else:
        obj = str(obj).encode(encoding)
    return obj
def uniqify(seq):
    ''' Order preserving uniqifier for list, tuple or string'''
    seen = set()
    return [x for x in seq if x not in seen and not seen.add(x)]
good luck
Mike
MarcCusumano
I'm running Python 2.6.5. Yes this will be part of a script that updates a File Geodatabase automatically used by ArcServer as a feature landbase. I want the email to send to myself and another individual when the process succeeds or fails.
manhunter trying to run that throws ImportError: No module named mah.wxDialogs
Thanks I appreciate the help.
MikeHunter
Here, this should work. Like I said, I copied this from a larger program I use, so the imports and references to frames, etc. needed to be cleaned up a little.
import smtplib
    if cc:
    for file in files:
        msg.attach(part)
    try:
        print str(error) + '  Cannot connect to Server!','Failed!'
        return
    server.ehlo()
    if tls:
        server.starttls()
    server.ehlo()
    if user:
    #then uniqify
    toall = to + cc
    try:
        print str(error),'Failed!'
    server.close()
    return
        else:
    else:
    return obj
def uniqify(seq):
    seen = set()
Mike
MarcCusumano
