Select only features of snapping errors throught the same orientation of the Lines
1340
10-21-2014 02:40 AM
JohannesBierer
I have created some models to check, if the snapping Geometrie of a digitalisation job is used and export these Features which aren't used correctly.
There are to much lines selected by this models, so I want to reduce the amount of lines which are selected incorrectly. An idea was to use the orientation of the lines?
Any suggestions?
