Select By Query from Items in Python List
15308
10-10-2016 12:53 PM
MitchHolley1
I'd like to create a SQL query statement which can select by multiple items in a Python string.
Can this be done?
lyr = r''
my_list = ['12','13','14','15']
for i in my_list:
    qry = "OBJECTID" + i
arcpy.SelectLayerByAttribute_management(lyr, qry)
The problem I'm having is formatting the list properly so it won't trip up the SQL statement.  Should I create a new list with the items separated by a "+" character?
Tags (3)
BradCollins1
Have you tried using the SQL "IN" Operator?
SQL IN Operator
http://www.w3schools.com/sql/sql_in.asp
# Path to the Layer
lyr = r"<NAME_OF_LAYER>"
# Integer list of OBJECTID(s)
oid = [12, 13, 14, 15]
# SQL Query
sql = "{} IN ({})".format("OBJECTID", ", ".join([str(n) for n in oid]))
# Tool Execution
arcpy.management.SelectLayerByAttribute(lyr, "NEW_SELECTION", sql)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The above format and list comprehension would yield the following string:
'OBJECTID IN (12, 13, 14, 15)'
The trick to this is that you need to create a string that represents valid SQL Syntax. This can be done is quite a few ways. I've listed a few quick options below.
# A few possible SQL Queries
sql = " OR ".join(["OBJECTID = {}".format(n) for n in oid])
# => OBJECTID = 12 OR OBJECTID = 13 OR OBJECTID = 14 OR OBJECTID = 15
sql = "{0} >= {1} AND {0} <= {2}".format("OBJECTID", min(oid), max(oid))
# => OBJECTID >= 12 AND OBJECTID <= 15
sql = "{} BETWEEN {} AND {}".format("OBJECTID", min(oid), max(oid))
# => OBJECTID BETWEEN 12 AND 15
BradCollins1
SQL IN Operator
# Path to the Layer
# SQL Query
# Tool Execution
MitchHolley1
Wow!  Amazing answer, Brad.  Thank you so much!
WentaoChe
You may try this one:
sql = ' "OBJECTID" in ' + str(tuple(oid))
