SearchCursor directory and subdirectories using python
6458
05-17-2015 12:35 AM
Yaron_YosefCohen
I work with arcmap 10.3 and python 2.7.8. I have more than 500 shapefiles located in many folders and subFolders. All Sub Folders are located in one large directory. I try with arcpy to detect all  shapefiles that have in their attribute table ,in field name "YEUD", the value 20. I search all shape files that begin with letters "mig". Finally i tried to print all the shapefiles that had been found with value 20 in it.
When i run this code i get en error:
import arcpy,os,sys,string,fnmatch
import arcpy.mapping
from arcpy import env
rootPath = r"C:\Project\layers"
pattern = 'mig*.shp'
fields = arcpy.ListFields(rootPath)
for root, dirs, files in os.walk(rootPath):
    for filename in fnmatch.filter(files, pattern):
        print( os.path.join(root, filename))
        for field in fields:
            with arcpy.da.SearchCursor(rootPath, field.name) as rows:
                for row in rows:
                    if field.name == 'YEUD':
                        if row == '20':
RuntimeError: ERROR 999999: Error executing function.
I can't understand why it doesn't work ?
curtvprice
MVP Alum
Here's a revised script for you.
import os
import fnmatch
import arcpy
        shp = os.path.join(root, filename)
        if arcpy.ListFields(shp, "YEUD"):
            print("{} has YEUD field".format(shp))
            with arcpy.da.SearchCursor(shp, ["YEUD"]) as rows:
                for row in rows:
                    if row[0] == 20:
                        print("{} has a record with YEUD = 20".format(shp))
                        break
A few notes:
  • Line 1: I'm adopting the Python convention (PEP-8) of putting imports on their own line (easier to edit out modules you don't need that way).
  • Line 9: You were running arcpy.ListFields on a folder at the beginning. You need to run it on a dataset, inside the loop.
  • Line 9: The approach I normally use to test for field existence is to call arcpy.ListFields(tbl, field_name), if it comes back as an empty list  [], this means the field was not there. An empty list is interpreted as False when used in an if statement.
  • Line 11: The cursor is run here on the shape file table, not rootPath.
  • Line 15: Once I find a row with YEUD = 20, I jump out of the loop so I don't report more than once if there are multiple rows with that value.
  • ArcGIS 10.1 SP1 and later includes a similar iterator function arcpy.da.walk, which can navigate both folder and geodatabase workspaces (not just file system folders as os.walk does).
curtvprice
MVP Alum
import os
import fnmatch
import arcpy
                for row in rows:
                    if row[0] == 20:
                        break
A few notes:
