Script tool parameters
940
08-27-2012 09:40 AM
JonPedder
This is my first foray into the ToolValidator class so this might be a very basic issue.
I???d like to read in a list of values from a list and display them as selectable in the script dialog as selectable options
Example:
Parameters in the script tool
[0] = name of mxd (required, arcmapdocument)
[1] = values (required, string, multivalue, filtered)
Can I assign a list such as
vals = [1,2,3,4,5,6,7]
self.params[1] = vals
In the end I???d like this to pull data from a featureclass using a searchcursor but for now I???m trying to see if it will even take the basic list of values.
RaphaelR
hi jon,
the help topic for the tool validator has a part about adding and filtering valuelists for script tool parameters:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00150000000v000000.htm
RaphaelR
hi jon,
