Script to contatenate the same field from several records
4608
14
09-26-2014 05:37 AM
JoseSanchez
Hi all,
I am looking for a script, preferably a Python script that reads all the records from a file and concatenates them in a result variable.
I am using ArcMap to "Select By Attributes" and I would like to have a way to format a list of IDs I am importing form a text file, or Ms Excell list. To build a Definition Query in the Query Builder window.
Input: (from xxx.txt)
341440
341444
341521
341534
341580
341664
341783
Output: (to zzz.txt)
ID=’341440’ OR ID= ‘341444’ OR ID= ‘341521’ OR ID= ‘341534’ OR ID= ‘341580’ OR ID= ‘341664’ OR ID= ‘341783’
Thanks
StevenGraf1
So you have 1 field with numbers such as 341423 and you want it to be ID = 341423?
You could field calculate using python.  This will calculate every record and add ID = in front of all the numbers.  Be sure that your field is a String/Text field.  ArcMap may import it in as an integer or double field.  I would create a new field and field calculate that one so you don't accidentally type something in wrong.
'ID = ' + !field!
JoseSanchez
how do you build the result string:
Result = "ID=’341440’ OR ID= ‘341444’ OR ID= ‘341521’ OR ID= ‘341534’ OR ID= ‘341580’ OR ID= ‘341664’ OR ID= ‘341783’"
IanGrasshoff
In python, you can open and read/write a file using..
f = open('your file - full path here', 'r')
You can also open it for writing using..
f = open('your file', 'w')
f.write("your text")
For your situation you might want to do this in a script (I am just giving you the overview)
1. Open the File
2. Read each line and concatenate the results to build your select query
    using this after you open it..
    for line in f:
            print line
3. Print the concatenated results or store the result in another file using f.write()
*Note, you might want to write this as a python function so you can pass in the file to read from and the column name to use for your result query.  I am not sure exactly how you are trying to use this.
I suggest you read this...
7. Input and Output — Python 2.7.8 documentation
JamesCrandall
Here's a way using NumPy:
import numpy as np
fout = open(r'H:\Documents\blah\output.txt', 'w')
values = np.genfromtxt(r'H:\Documents\blah\input.txt')
for val in values:
    writevalue = "ID='" + str(val) + "' OR "
    fout.write(writevalue)
fout.close()
JamesCrandall
I tried to modify my original post but it won't let me because GeoNet is not a real forum.
Anyway... I noticed that the values will come convert over as decimal, which you may not want.  So, simply modify the genfromtxt() method to include the output format as strings.
values = np.genfromtxt(r'H:\Documents\blah\input.txt',dtype='str')
Here's the updated code:
import numpy as np
for val in values:
    print writevalue
fout.close()
JamesCrandall
Let's get a bit more pythonic and into just 4 lines:
fout.writelines("ID='" + str(val) + "' OR " for val in values)
fout.close()
Zeke
Honored Contributor
Even more pythonic! Except I don't know how to format as code on the new forums here...
  1. with open(r'H:\Documents\blah\'output.txt', 'w') as fout:
  2.     values = np.genfromtxt(r'H:\Documents\blah\input.txt',dtype='str')
  3.     fout writelines("ID='" + str(val) + "' OR " for val in values)
Also, for your output, rather than a bunch of OR clauses, you could make a python list and test using IN:
ID IN ['34012', 35078', '39222'...]
curtvprice
Zeke
Honored Contributor
Thanks Curtis! I saw the >> icon, but hovering over it said Insert, which is not quite as intuitive as something like Format.
