Running arcpy64 from ArcGIS Server10.1 on 64 bit server
2209
03-01-2012 06:11 PM
TedCronin
When I first run arcpy in Wing on a 64 bit server, I see:
>>>import arcpy
Creating catid files
C:\Users\tcronin\AppData\Local\ESRI\Server10.1\Configuration\CATID\arcgis_indexer.catid.ecfg
Create JARID File...
outfile=C:\Users\tcronin\AppData\Local\ESRI\Server10.1\Configuration\JARID\arcgis_indexer.jarid.ecfg
Is this the expected behavior?  I am assuming this is happening since Server install does not create the .pth file and does not automatically configure.  Is this a correct assumption?  Will there be a comparison chart showing the differences between 32 and 64 bit versions of arcpy?  This is A OK right to run python this way.  I would rather just run everything here since we tend to kill (crash) python 32 with data overhead.
JasonScheirer
Esri Alum
Ignore the superfluous log messages behind the curtain. It will run just fine.
JasonScheirer
Esri Alum
