Run Python Script from Model Builder outside Arcmap
2045
5
01-10-2014 06:25 AM
TylerScott2
I have created a model builder that appends a Query Layer (view) in the SDE to an existing featureclass an this process works
in Arcmap fine. However when I run the script out side arcmap I receive the following error:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000338: Inputs must be either all Feature Classes, Tables or Rasters; not mixed.
Failed to execute (Append)
Any Suggestions or workarounds to have this run outside Arcmap?
MichaelVolz
Esteemed Contributor
Can you post the code to the forum, removing any names that might be confidential?
TylerScott2
# Set the necessary product code
# import arcinfo
# Import arcpy module
import arcpy
# Script arguments
AVL_DBO_Citation_Archive = arcpy.GetParameterAsText(0)
if AVL_DBO_Citation_Archive == '#' or not AVL_DBO_Citation_Archive:
    AVL_DBO_Citation_Archive = "Database Connections\\AVL.sde\\AVL.DBO.Citation_Archive" # provide a default value if unspecified
AVL_DBO_Citation_Archive__2_ = arcpy.GetParameterAsText(1)
if AVL_DBO_Citation_Archive__2_ == '#' or not AVL_DBO_Citation_Archive__2_:
    AVL_DBO_Citation_Archive__2_ = "Database Connections\\AVL.sde\\AVL.DBO.Citation_Archive" # provide a default value if unspecified
AVL_DBO_Citation_Archive__3_ = arcpy.GetParameterAsText(2)
if AVL_DBO_Citation_Archive__3_ == '#' or not AVL_DBO_Citation_Archive__3_:
    AVL_DBO_Citation_Archive__3_ = "Database Connections\\AVL.sde\\AVL.DBO.Citation_Archive" # provide a default value if unspecified
AVL_DBO_Citation_Archive__4_ = arcpy.GetParameterAsText(3)
if AVL_DBO_Citation_Archive__4_ == '#' or not AVL_DBO_Citation_Archive__4_:
    AVL_DBO_Citation_Archive__4_ = "Database Connections\\AVL.sde\\AVL.DBO.Citation_Archive" # provide a default value if unspecified
CURRENT_CITATIONS = arcpy.GetParameterAsText(4)
if CURRENT_CITATIONS == '#' or not CURRENT_CITATIONS:
    CURRENT_CITATIONS = "CURRENT CITATIONS" # provide a default value if unspecified
# Local variables:
# Process: Append
arcpy.Append_management("'CURRENT CITATIONS'", AVL_DBO_Citation_Archive, "NO_TEST", "Equip_No \"Equip_No\" true true false 10 Text 0 0 ,First,#,CURRENT CITATIONS,Equip_No,-1,-1;RadioCode \"RadioCode\" true true false 10 Text 0 0 ,First,#,CURRENT CITATIONS,RadioCode,-1,-1;WorkDateTime \"WorkDateTime\" true true false 36 Date 0 0 ,First,#,CURRENT CITATIONS,WorkDateTime,-1,-1;Notes \"Notes\" true true false 40 Text 0 0 ,First,#,CURRENT CITATIONS,Notes,-1,-1", "")
# Process: Delete Identical
arcpy.DeleteIdentical_management(AVL_DBO_Citation_Archive__2_, "WorkDateTime", "", "0")
TylerScott2
Thanks, ArcMap 10.2.1
TylerScott2
I adjusted the model per you suggestion and I received the following error outside Arcmap.
ERROR 000732: Input Features: Dataset CURRENT CITATIONS does not exist or is not supported
Failed to execute (FeatureClassToFeatureClass
The Current Citations is a (SDE View)
The Model runs in arcmap.
Code:
# import arcinfo
import arcpy
# Script arguments
AVL_DBO_Current_Citations = arcpy.GetParameterAsText(0)
if AVL_DBO_Current_Citations == '#' or not AVL_DBO_Current_Citations:
    AVL_DBO_Current_Citations = "Database Connections\\AVL.sde\\AVL.DBO.Current_Citations" # provide a default value if unspecified
AVL_sde = arcpy.GetParameterAsText(1)
if AVL_sde == '#' or not AVL_sde:
    AVL_sde = "Database Connections\\AVL.sde" # provide a default value if unspecified
CURRENT_CITATIONS = arcpy.GetParameterAsText(2)
HISTORIC_CITATIONS = arcpy.GetParameterAsText(3)
if HISTORIC_CITATIONS == '#' or not HISTORIC_CITATIONS:
    HISTORIC_CITATIONS = "HISTORIC CITATIONS" # provide a default value if unspecified
HISTORIC_CITATIONS__5_ = arcpy.GetParameterAsText(4)
if HISTORIC_CITATIONS__5_ == '#' or not HISTORIC_CITATIONS__5_:
    HISTORIC_CITATIONS__5_ = "HISTORIC CITATIONS" # provide a default value if unspecified
HISTORIC_CITATIONS__3_ = arcpy.GetParameterAsText(5)
if HISTORIC_CITATIONS__3_ == '#' or not HISTORIC_CITATIONS__3_:
    HISTORIC_CITATIONS__3_ = "HISTORIC CITATIONS" # provide a default value if unspecified
HISTORIC_CITATIONS__4_ = arcpy.GetParameterAsText(6)
if HISTORIC_CITATIONS__4_ == '#' or not HISTORIC_CITATIONS__4_:
    HISTORIC_CITATIONS__4_ = "HISTORIC CITATIONS" # provide a default value if unspecified
CURRENT_CITATIONS__2_ = arcpy.GetParameterAsText(7)
if CURRENT_CITATIONS__2_ == '#' or not CURRENT_CITATIONS__2_:
    CURRENT_CITATIONS__2_ = "CURRENT CITATIONS" # provide a default value if unspecified
# Local variables:
# Process: Feature Class to Feature Class
arcpy.FeatureClassToFeatureClass_conversion(CURRENT_CITATIONS, AVL_sde, "Current_Citations", "", "Equip_No \"Equip_No\" true true false 10 Text 0 0 ,First,#,CURRENT CITATIONS,Equip_No,-1,-1;RadioCode \"RadioCode\" true true false 10 Text 0 0 ,First,#,CURRENT CITATIONS,RadioCode,-1,-1;WorkDateTime \"WorkDateTime\" true true false 36 Date 0 0 ,First,#,CURRENT CITATIONS,WorkDateTime,-1,-1;Notes \"Notes\" true true false 40 Text 0 0 ,First,#,CURRENT CITATIONS,Notes,-1,-1", "")
# Process: Append
arcpy.Append_management("'CURRENT CITATIONS'", HISTORIC_CITATIONS, "NO_TEST", "Equip_No \"Equip_No\" true true false 10 Text 0 0 ,First,#,CURRENT CITATIONS,Equip_No,-1,-1;RadioCode \"RadioCode\" true true false 10 Text 0 0 ,First,#,CURRENT CITATIONS,RadioCode,-1,-1;WorkDateTime \"WorkDateTime\" true true false 36 Date 0 0 ,First,#,CURRENT CITATIONS,WorkDateTime,-1,-1;Notes \"Notes\" true true false 40 Text 0 0 ,First,#,CURRENT CITATIONS,Notes,-1,-1", "")
arcpy.DeleteIdentical_management(HISTORIC_CITATIONS__3_, "WorkDateTime", "", "0")
MichaelVolz
Can you get a print out of what the HISTORIC_CITATIONS variable contains in your append statement?
