Run another python script via a batch file
3217
08-31-2012 04:31 AM
JamesMorrison1
Hello everyone.
A little bit more python than gis question. Sorry.
script:  main.py
script:  child.py
batch file: run.bat
main.py basically loads feature class data into SDE
so during gp.Append_management(my_source, my_target, "NO_TEST") I wish a sperate command window to open and run child.py which reports back a row count every 10 seconds
In main.py I want to pass two parameters to run.bat (fc_name, total_count)
The run.bat file will then pass on these parameters to child.py
The code in main.py should continue running and child.py should open in a sperate command window - hence why I though about via a .bat file.
I have tried os.spawn, subprocess.call, os.popen, os.startfile but sadly without success.
Can anyone help me with the syntax in main.py, run.bat and child.py to achieve this? Advice appreciated.
ChristopherBlinn1
This might be a helpful article.
