Run a python code in ArcGIS
14229
34
01-13-2015 05:26 PM
DuminduJayasekera
I need to make it run the following code in arcGIS but this is not written to run in arcgis but in visual studio. I tried but it DOES NOT work. Can someone help me to write thin in python so that I can add as a script in ArcGIS.? I am planning to import this as a script after making this a working code.
Any help is highy appreciated.
Thanks.
import arcpy
from arcpy import env
from arcpy.sa import *
#Check out the ArcGIS Spatial Analyst extension license
arcpy.env.scratchWorkspace = "c:\temp\tmp"
env.workspace = "c:\DEMPreProcess"
LULC = Raster("C:\DEMPreProcess\VietnamLULC_Resample.tif")
Simard = Raster("C:\DEMPreProcess\MajoritySTOht.tif")
resultmap = Simard
for i in range(1,14):
    if i == 1:
        number = 0.4
    elif i == 2:
        number = 0.4
    elif i == 3:
        number = 0.4
    elif i == 4:
        number = 0.4
    elif i == 5:
        number = 0.4
    elif i == 6:
        number = 0.3
    elif i == 7:
        number = 0.3
    elif i == 8:
        number = 0.3
    elif i == 9:
        number = 0.3
    elif i == 10:
        number = 0.3
    elif i == 11:
        number = 0
    elif i == 12:
        number = 0.3
    elif i == 13:
        number = 0
    elif i == 14:
        number = 0.3
resultmap = Con(LULC == i,Simard*number,resultmap)
resultmap.save("C:\DEMPreProcess\MajoritySTOhtPer.tif")
Tags (1)
XanderBakker
Esri Esteemed Contributor
Oops, that's right the tool checks the license out, does the work and then returns the license... If you need the extension for the other processes in the tool, then the error occurs... Good to keep in mind! Thanks for posting back.
DuminduJayasekera
Thanks again for your feedback
DuminduJayasekera
Hi Xander,
The process used to obtain viet_LULC_30.tif is correct. As you said it was resampled to 30 m. If you open the attribute table, the values are ranging from 0 to 16 and if you see into layer properties min is 0 and max is 16. So, I don't understand where you saw -1. Yes the code was written to use from 1 to 14 because those are the land use types I am interested.
OK. How can I convert that to python code?
Please see the link to download MajoritySTOht.tif  file
https://bft.usu.edu/t3vh9
Please open the Vietnam_Test tool that I am using to perform the GIS process and calculations.
Thanks again,
JamesCrandall
The above code is run in Visual Studio
What project type in VS allows you run python code?  Or are you executing a .bat file from the application you developed in Visual Studio (there's lots of different types of apps you can develop, VS is just the IDE).
XanderBakker
Why not reclassify the LULC raster (holding the 14 integer values) using ReclassByASCIIFile with a ASCII file that has the relation between the input and output values like this:
1 : 0.4
2 : 0.4
3 : 0.4
4 : 0.4
5 : 0.4
6 : 0.3
7 : 0.3
8 : 0.3
9 : 0.3
10 : 0.3
11 : 0
12 : 0.3
13 : 0
14 : 0.3
... and then multiply the reclassified raster by the Simard raster.
