row.shape for layer ?
1831
6
10-25-2011 04:06 AM
OlivierOlivier
Hi
Can someone be so kind to explain why when I use those  lines
rows = gp.SearchCursor(infc)
row = rows.Next()
feat=row.shape
it works when infc is a shapefile but not when it's a layer ? In this case, I get "Field shape does not exist" even if it exists when I open attributes in ArcView.
Thanks very much, sorry for a such basic question,
Olivier
ChrisSnyder
Honored Contributor
The 'shape' field isn't always called shape...
dsc = gp.describe(infc) #or your featurelayer
rows = gp.SearchCursor(infc)  #or your featurelayer
row = rows.Next()
feat=row.getvalue(dsc.oidFieldName)
OlivierOlivier
Hi Chris,
Thanks for your answer. It seems to work but the problem is that after I used
partcount =feat.PartCount # Count the number of points in the current multipart feature
and I get this message :
AttributeError: 'int' object has no attribute 'PartCount'
That means that the feat objet I get is not the same 'shape' ?
LoganPugh
Try shapeFieldName instead of oidFieldName.
OlivierOlivier
That's ok. Sorry for being stupid, OidFieldName sounded strange to me but I didn't thank further.
Thanks very much for your help Chris !
Olivier
ChrisSnyder
Honored Contributor
Woops - Thanks Logan...
Yes, I meant shapeFieldName, not oidFieldName (although oidFieldName is quite usefull sometimes as well).
I didn't have my coffe yet...
OlivierOlivier
I didn't get my coffee too, I thought previous answer was Chris's, sorry Logan.
Thanks to both of you, you helped much !
Olivier
