Reproject Las Dataset using arcpy in VisualCode
1242
06-11-2025 11:27 AM
CarlaNardinocchi
Hi, I am starting to build a project in Visual Code using the ArcPy library.
I need to convert a LAS file defined in a geographic coordinate system (6706) into a projected file (same ellipsoid, 7794-UTM Italy zone).
Everything works in ArcGIS Pro using ExtractLas, but the Python function (https://pro.arcgis.com/en/pro-app/latest/tool-reference/3d-analyst/extract-las.htm) has no parameters for reprojecting the coordinate system.
I have tried using ProjectLas (https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/project-las.htm), which should be in arcpy.management, but I received an AttributeError stating that the module 'arcpy.management' has no attribute 'ProjectLas'.
Can you please tell me how I can perform this reprojection in a Visual Code Python script?
Thank you very much for any help!
DanPatterson
MVP Esteemed Contributor
Project las is new to arcgis pro 3.5
Project LAS (Data Management)—ArcGIS Pro | Documentation
you will see there is only 3.5 as the selectable version
... sort of retired...
CarlaNardinocchi
Thanks for the information, I will not spend more time on  ProjectLas, but what can I use in the Visual Code  python script to reproject my las dataset?
jrolson14
I've used LAStools in a mostly ArcPy script before to work with lidar. If you create a command line string including the path of the specific tool and the parameters, the script can then run it using os.system().
CarlaNardinocchi
Thank you for your help!
I would like to share the solution I found with you and anyone who may have the same problem.
@jrolson14 I don't like using LasTools because I only have the free toolbox, which has some limitations. I prefer to avoid it, especially for coordinate projection, which is GIS-related.
I updated to ArcGIS Pro 3.5, and, as suggested by @DanPatterson , I stopped working with ProjectLas(). However, I decided to continue working with ExtractLas() because it was the function I was using in ArcGIS Pro.
I learned that I had to set the projection in the environment. Using the following code
# Output coordinate system (EPSG:7794)
output_coordinate_system = arcpy.SpatialReference(7794)
# Set the environment
arcpy.env.outputCoordinateSystem = output_coordinate_system
# Use the Extract LAS tool to project the LAS dataset
arcpy.ddd.ExtractLas(input_las,output_folder,name_suffix='_7794')
And I was able to project the LAS dataset from epsg:6706 (geographic coordinates) to epsg:7794 (projected coordinates with the same datum and ellipsoid).
