Replace Null values with 0 in many fields
5449
6
03-02-2016 10:10 AM
JAKERODEL
Can somebody point out what I am doing wrong here?  I am trying to get a list of fields (PrecipFields) and replace all null values with 0.  When I call out a specific field it works fine.  When I use list of fields it looks as if it runs but non of the values are updated.
>>> with arcpy.da.UpdateCursor("asciiPoints",["ippt_allsites_spas1325_024_19230927_0700_UTC"]) as cursor:
...     for row in cursor:
...         if row[0] == None:
...             row[0] = 0
...             cursor.updateRow(row)
Works fine...
My field list I want to use...
>>> print PrecipFields
[u'ippt_allsites_spas1325_021_19230927_0400_UTC', u'ippt_allsites_spas1325_022_19230927_0500_UTC', u'ippt_allsites_spas1325_023_19230927_0600_UTC', u'ippt_allsites_spas1325_024_19230927_0700_UTC', u'ippt_allsites_spas1325_025_19230927_0800_UTC', u'ippt_allsites_spas1325_026_19230927_0900_UTC', u'ippt_allsites_spas1325_027_19230927_1000_UTC', u'ippt_allsites_spas1325_028_19230927_1100_UTC'
This is a shortened list.  There could be hundreds of fields.
Nothing happens...
>>> with arcpy.da.UpdateCursor("asciiPoints","PrecipFields") as cursor:
...             row[0] = 0
RuthBowers
Hi, Jake. You have to enumerate through all the fields. As Darren pointed out, row[0] refers to the first column in the row. I pasted in an example below. When you use enumerate, using my example, i is the number of the column position from the left (of the columns included in the cursor), starting at 0. c is the corresponding value from the list being enumerated through, in your case, the column name.
# Assuming PrecipFields is a python list of column names.
with arcpy.da.UpdateCursor("asciiPoints", PrecipFields) as cursor:
    for row in cursor:
        updated = False
        for i, c in enumerate(PrecipFields):
            if row == None:
                row = 0
                updated = True
        if updated == True:
I hope this is helpful.
DarrenWiens2
Remove the quotes around "PrecipFields". Quotes mean text/string. No quotes means variable, in your case, a list of field names.
JAKERODEL
That doesn't work for me either.  No error just nothing happens.
DarrenWiens2
You'll also have to loop through the fields in your field list. row[0] means look at the first field only.
JAKERODEL
This would do that right?  Same result...
>>> with arcpy.da.UpdateCursor("asciiPoints",PrecipFields) as cursor:
...         for field in PrecipFields:
...              row[0] = 0
Also tried this...
>>> i = 0
...       if row == None:
...          row = 0
...          i += 1
RuthBowers
    for row in cursor:
        updated = False
            if row == None:
                row = 0
                updated = True
        if updated == True:
JAKERODEL
Perfect.  Thanks to both of you!
