Removing characters from a Feature Class file name
8251
12
02-14-2021 01:25 PM
MichaelTomiak
This should be a simple answer ... I'm trying to just remove the first 25 characters from a list (>90 in number) of Feature classes (raster datasets) within a .gdb.
All the file names are named the same except for the last 9 digits (hence why I am trying to remove the first 25).
I would then like to add some standard text to all the FCs (in the example "Hello")
My attempt from other threads comprises the following (but has not worked so far):
import arcpy
import os
dir = r'C:\Users\X\Desktop\X\X.gdb'
arcpy.env.workspace = dir
for ras in arcpy.ListRasters ("*"):
print (ras)    #original raster name
basename = ras.split("*")[:25]    #strips the first 25 characters from original raster name
newrastername = "Hello" + basename
print (newrastername)
arcpy.CopyRaster_management(ras, newrastername)   #create a new raster with the new/updated name
Error received:
SyntaxError                               Traceback (most recent call last)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\ast.py, in parse:
Line 35:    return compile(source, filename, mode, PyCF_ONLY_AST)
SyntaxError: Missing parentheses in call to 'print'. Did you mean print(ras #original raster name)? (<string>, line 😎
DanPatterson
MVP Esteemed Contributor
Code formatting on the esri Community will help
Code formatting ... the Community Version - GeoNet, The Esri Community
... sort of retired...
MichaelTomiak
Cheers Dan. This is really helpful as I am definitely not a coder and learning/applying only the very basics of Python to help me with the GIS aspect of my technical work.
I used Rename tool for this with %Name% in the output name field originally, but that's only helpful for appending information and not (as my original Question suggestions) that helpful for removing, or slicing up filenames.
by Anonymous User
Not applicable
Simple oneliner for fun, IF the 25 characters are all the same.
newrastername = ras.replace('THISIS25CHARACTERSLONGMAN', 'Hello')
