Refresh Map during export layout as PDF using python script
482
6
07-20-2024 11:15 AM
MohamedHassan17
I have a python script that querying some values and appending them to Layout. I'm applying symbology, labeling, and definition query. the script running well, but when exporting to PDF the symbology and labeling don't appears.
Although when I zoom in or out from the layout all appears.
the first image from the map (with labeling &symbology)
the second image from the layout (without labeling &symbology)
First ImageFirst Image
second imagesecond image
RhettZufelt
MVP Notable Contributor
Are you saving the map after the updates, symbology, etc. but before the PDF export?
R_
TonyAlmeida
Maybe add,
time.sleep(4) ensures that all changes have time to be fully applied before exporting to PDF.
import arcpy
import time
# Define your project and layout
aprx = arcpy.mp.ArcGISProject("CURRENT")
layout = aprx.listLayouts()[0]
# Define your map frame and map
map_frame = layout.listElements("MAPFRAME_ELEMENT")[0]
map_view = map_frame.map
layer = map_view.listLayers()[0]  # Modify as per your layer
# Refresh the map view
map_frame.camera.setExtent(map_frame.camera.getExtent())  # Trigger a refresh by resetting the extent
# Wait for a moment to ensure all changes are applied
time.sleep(4)
# Export to PDF
output_pdf = r"path_to_your_output.pdf"
layout.exportToPDF(output_pdf)
MohamedHassan17
Yes, I did but not working.
TonyAlmeida
Maybe increase the sleep time.
MohamedHassan17
the issue still occurred.
TonyAlmeida
Maybe convert labels to annotation using, arcpy.cartography.ConvertLabelsToAnnotation, before the export.
