Raster save method using variable
2740
12-27-2013 05:27 AM
anTonialcaraz
I'm trying to find out how to permanently save a raster using a workspace variable + Raster name with little success so far.
In the Help it only shows how to do it hard-coding the output.
Please see code below.
import arcpy import string from arcpy import env arcpy.env.overwriteOutput=True from arcpy.sa import * arcpy.CheckOutExtension("Spatial")  # Variables  OutLocation = arcpy.GetParameterAsText(0)  Raster1 = arcpy.Raster(arcpy.GetParameterAsText(1))  Raster2 = arcpy.Raster(arcpy.GetParameterAsText(2))  # Calculation and save  CDF = Raster1 * Raster2  OutFile = "CDF"                          FullOutFile = OutLocation + OutFile     # For example: r"Q:\LFP_GLOBAL\OUTPUT.gdb\CDF" CDF.save(FullOutFile)
Any help would be greatly appreciated.
Many thanks
JakeSkinner
Esri Esteemed Contributor
You will just need to add "\\" to your FullOutFile variable.  Ex:
FullOutFile = OutLocation + "\\" + OutFile
Previously you were trying to save the output to:
Q:\LFP_GLOBAL\OUTPUT.gdbCDF
The above will save write the correct path:
JakeSkinner
anTonialcaraz
Once again, thank you very much indeed Jake.
