raster doesn´t appear in exported layout
1963
03-28-2023 04:17 PM
kradijaf
Need to make maps for PNG files I georeferenced and some vector layers, each layer lies within a georeferenced PNG. They are small (around 300 kB) files. After georeferencing them, they tend to dissapear when their feature layer is set to visible and I switch on/off other raster layer in same Map. Building pyramids, putting the PNG into other map or project or using raster made by exporting it doesn´t help. Even when the PNG/exported raster is visible in layout when I try to export the layout, only vector layers are visible in the output. Extent of the layout is correct, the problem is in the raster file.
DanPatterson
what about the raster properties?
... sort of retired...
kradijaf
What exactly do you mean?
DanPatterson
extent, cell size, coordinate system,  basically its properties
kradijaf
kradijaf_0-1680075207004.pngkradijaf_0-1680075207004.pngkradijaf_1-1680075233000.pngkradijaf_1-1680075233000.png
Cell size unit = meter
