Raising exceptions in a Python thread
1549
05-21-2013 03:43 AM
JamesCrandall
MVP Alum
Ok I'm a newbie in this area so I need to understand how exceptions are raised...
Below is my Add-in code which is essentially the example for a button on a toolbar in the ArcGIS 10.1 Python wizard help.
I've added the error handling.....
So the problem is that nothing happens - the button does not work but neither are there any exceptions raised...
So what am I doing wrong? The add-in toolbar appears in the project, the button is enabled but no exceptions appear in the python window and I have no indication the code is executing.
import arcpy
import pythonaddins
class ButtonClass11(object):
    """Implementation for test_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
try:
# Implementation of OnClick method of Button's class
    def onClick(self):
        # Get the current map document and the first data frame.
        mxd = arcpy.mapping.MapDocument('current')
        df = arcpy.mapping.ListDataFrames(mxd)[0]
        # Call the zoomToSelectedFeatures() method of the data frame class
        df.zoomToSelectedFeatures()
    pass
except Exception, e:
    traceback.print_exc()
Maybe a dumb question, but do you have any features selected when you click the button?
You can also put a print statement before and after the line you expect to 'do stuff'.  In the code above, you can test the zoomToSelectedFeatures method like so,
print "...attempting to run zoomToSelected"
print "...finished running zoomToSelected"
This will output the two statements in the Python window when you click the add-in button.  Just a quick and dirty way to debug.
JasonScheirer
Esri Alum
Indentation error. Putting the try: statement at that indent level implicitly takes you out of the class definition and just defines an onClick function not bound to anything. Make it look like this:
import arcpy
import pythonaddins
import traceback
    def __init__(self):
        self.enabled = True
    def onClick(self):
        try:
        except Exception as e:
ColinConstance
Thanks!;)
     Now thats a lesson in indentation I hopefully won't forget..
