Questions regarding the difference between reading a geometry and writing a geometry?
1514
12-13-2022 06:04 AM
RPGIS
by MVP Regular Contributor
I have some questions regarding geometries in python. I am currently working on a script to read/write the geometry of one feature class and analyzing the contains method to determine if the center of a line is contained by the input polygon geometry. A question that I have is, what is the difference between making a new geometry object vs reading and utilizing the existing geometry object?
Ex: ['SHAPE@'] field to read the geometry vs Polygon (inputs, {spatial_reference}, {has_z}, {has_m}) to make a new geometry object.
The other question is can this be utilized with the contains method or will I need to create a whole new object in order to do so?
Any help on this would be greatly appreciated.
JohannesLindner
There is no difference. Reading the SHAPE@ token returns a geometry object, same as when you create it on your own.
extracted_geometry = [row[0] for row in arcpy.da.SearchCursor("TestPoints", ["SHAPE@"])][0]
created_geometry = arcpy.PointGeometry(arcpy.Point(523433, 5848821), arcpy.SpatialReference(25832))
extracted_geometry
#<PointGeometry object at ...>
created_geometry
contains() is a method of the Geometry classes, so you can call it on the extracted geometries without problem.
Have a great day!
Johannes
JohannesLindner
extracted_geometry
created_geometry
Have a great day!
Johannes
