Query in SearchCursor or Select by attribute?
768
03-20-2012 09:59 AM
zhengniu1
My question is: which one is faster, using Query in SearchCursor or SelectlaybyAttribute to retrieve desired values from table in file geodatabase?
MathewCoyle
Honored Contributor
If you are reading values, the search cursor with a where clause is faster. It also depends on what you are extracting and the size of your dataset, the gains may be minimal.
zhengniu1
I have a script to run distance-based point clustering. it takes almost 4 mins to finish only 600 pts. do you mind to have a look? help me to facilitate the process?
