pythonw.exe has encountered a problem and needs to close
1344
08-16-2011 01:26 PM
MariellaCarbajal
Hello everybody
I hope somebody can help me. I wrote a code in python, it run well in my friend's computer and just for one raster (without "for") in mine.
When I run the code, It only do the process for the first raster and then the following message appears "pythonw.exe has encountered a problem and needs to close."
Thanks in advance.
DanPatterson_Retired
You need to post the code within code blocks so it can be examined
AdrianMarsden
Honored Contributor
Old thread, but I have the same issue on ANY Python script - I've just struggled updating a PC from 9.3.1 to 10.1 - I had to do a manual de-installation.
MichaelVolz
Esteemed Contributor
Can you post one of your python scripts that is not working in 10.1?
AdrianMarsden
Honored Contributor
I think this issue was down to a bad de-installation of previous versions, so not important - I restored the previous snapshot (it a Virtual PC) and will try again,
Cheers
ACM
