Python Won't Run Spatial Autocorrelation Script Twice
2352
10-09-2012 10:38 AM
AndrewStauffer1
I'm trying to calculate a Global Moran's I statistic on a [long] list of point files using python.  I have set up my code to loop through the arcpy.SpatialAutocorrelation_stats script as shown below.  The loop runs through the first shapefile without a problem and prints out the Moran's I Summary Table.  When it gets to the second shapefile, it crashes with a strange error.
I can manually run the Spatial Autocorrelation Script in batch form without a problem from ArcCatalog.  However, I don't want to parse through the Results window later.
I am using ArcGIS 10.1 with Python XY (Spyder) 2.7 on a Windows 7 64-bit machine.
Has anyone encountered this error or found any solutions?
Andy
import arcpy
dataPath = r"c:\data"
elevationPoints = ["elevPts1.shp", "elevPts2.shp"]
elevationPoints = ["id_1pt.shp","id_11pt.shp"]
dataPath = r"C:\Users\Andy\Desktop\BlackbirdKnob_WV\tempPts"
for i in range(len(elevationPoints)):
    arcpy.SpatialAutocorrelation_stats (dataPath+"\\"+elevationPoints, "GRID_CODE", "NO_REPORT" , "FIXED_DISTANCE_BAND", "EUCLIDEAN_DISTANCE" ,"NONE","15")
This is the error message that comes up:
  File "C:\Users\Andy\Desktop\MoransLoop.py", line 20, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\stats.py", line 403, in SpatialAutocorrelation
    raise e
arcgisscripting.ExecuteError:
  File "c:\program files (x86)\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 21, in <module>
    import SSReport as REPORT
  File "c:\program files (x86)\arcgis\desktop10.1\ArcToolbox\Scripts\SSReport.py", line 17, in <module>
    import pylab as PYLAB
  File "C:\Python27\lib\site-packages\pylab.py", line 1, in <module>
    from matplotlib.pylab import *
  File "C:\Python27\lib\site-packages\matplotlib\pylab.py", line 264, in <module>
    from matplotlib.pyplot import *
  File "C:\Python27\lib\site-packages\matplotlib\pyplot.py", line 23, in <module>
    from matplotlib.figure import Figure, figaspect
  File "C:\Python27\lib\site-packages\matplotlib\figure.py", line 18, in <module>
    from axes import Axes, SubplotBase, subplot_class_factory
  File "C:\Python27\lib\site-packages\matplotlib\axes.py", line 338, in <module>
    class Axes(martist.Artist):
  File "C:\Python27\lib\site-packages\matplotlib\axes.py", line 2051, in Axes
    def grid(self, b=None, which='major', axis='both', **kwargs):
  File "C:\Python27\lib\site-packages\matplotlib\docstring.py", line 103, in dedent_interpd
    return interpd(dedent(func))
  File "C:\Python27\lib\site-packages\matplotlib\docstring.py", line 36, in __call__
    func.__doc__ = func.__doc__ and func.__doc__ % self.params
KeyError: 'Line2D'
Failed to execute (SpatialAutocorrelation).
AndrewStauffer1
Found a temporary fix.  Since it seems that the the first few errors were being derived from the MoransI.py module within the SpatialAutocorrelation_stat tool, it was re-loaded in the script with hopes that it would resolve the problem.  It worked, but is still a bit of an odd work-around.  See the below code that allowed the Spatial Autocorrelation tool to be iteratively executed:
import arcpy
arcpy.env.overwriteOutput
    import MoransI
    arcpy.SpatialAutocorrelation_stats (dataPath+"\\"+elevationPoints, "GRID_CODE", "#" , "FIXED_DISTANCE_BAND", "EUCLIDEAN_DISTANCE" ,"NONE","15")
ImeeNecesito
i have an error also regarding spatial autocorrelation (moran;s I):
Executing: SpatialAutocorrelation calculationdepth FID_tmhous NO_REPORT INVERSE_DISTANCE EUCLIDEAN_DISTANCE NONE # #
Start Time: Tue Jul 08 15:35:41 2014
Running script SpatialAutocorrelation...
WARNING 000853: The default neighborhood search threshold was 7349.512418 Meters.
  File "c:\program files\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 610, in <module>
    setupGlobalI()
  File "c:\program files\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 88, in setupGlobalI
    threshold = threshold, exponent = exponent)
  File "c:\program files\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 157, in __init__
    self.construct()
  File "c:\program files\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 361, in construct
    nhVals, weights)
  File "c:\program files\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 405, in processRow
    self.wij[ij] = w
MemoryError
Failed at Tue Jul 08 15:36:01 2014 (Elapsed Time: 20.00 seconds)
i already looked the same error in the internet but nobody tried to answer this question (from other people)..
i hope someone could help me...-.- please
