Python Toolbox Toolset
7535
06-10-2013 12:40 PM
DavidAllen
Can someone post an example of how to configure and use the toolsets in a Python Toolbox?
The help barely mentions that this is even an option, and the only code example I can find is to set:
self.category = ???Toolset Name???
but when you have:
self.tools = [tool1, tool2]
I just get the regular tools listed in the toolbox without a toolset.
How do you tell it to put the tools into the category?
ShaunWalbridge
I've create an example, example-toolbox.pyt that hopefully clarifies (also as a Github Gist😞
import arcpy
class Toolbox(object):
    def __init__(self):
        self.label = u'Example_Toolbox'
        self.alias = ''
        self.tools = [FirstTool, SecondTool, ThirdTool]
class FirstTool(object):
    def __init__(self):
        self.label = u'First Tool'
        self.description = u''
        self.canRunInBackground = False
        self.category = "Import"
    def getParameterInfo(self):
        return
    def execute(self, parameters, messages):
        pass
class SecondTool(object):
    def __init__(self):
        self.label = u'Second Tool'
        self.category = "Export"
        return
        pass
class ThirdTool(object):
    def __init__(self):
        self.label = u'Third Tool'
        return
        pass
You'll then have two categories within your toolbox: Export and Import, Import will contain one item and Export will contain two.
cheers,
Shaun
ShaunWalbridge
import arcpy
    def __init__(self):
        self.alias = ''
    def __init__(self):
        return
        pass
    def __init__(self):
        return
        pass
    def __init__(self):
        return
        pass
cheers,
Shaun
BartłomiejStaroń
How to create toolset in toolset? It is possibile?
ShaunWalbridge
Sure, just embed '\' separators between the toolsets. Here's an example where the two "Export" tools will be in separate toolsets, nested underneath the parent (also on GitHub😞
import arcpy
    def __init__(self):
        self.alias = ''
    def __init__(self):
        return
        pass
    def __init__(self):
        self.category = "Export\\GeoJSON"
        return
        pass
    def __init__(self):
        self.category = "Export\\TopoJSON"
        return
        pass
DavidAllen
cheers,
Shaun
Aha! I found three references to adding the self.category but none said that it goes in the individual tool class rather than the toolbox class.
Perfectly understandable now.  Thanks!!
