Python Toolbox to create buffer layer
2994
6
08-25-2025 10:12 AM
BrandonPrice1
Hello,
Can somebody advise me on how to code this properly? The below script was attempted using google AI snippets to create an in memory buffer layer of 500 feet based on the feature currently selected in the map. It throws an error when trying to run it. Also, if there is any advice on creating an editable layer from all features that intersect the buffer. Eventually, I plan to publish everything as a GP service.
import arcpy
import arcpy.mp
class Toolbox:
    def __init__(self):
        self.label = "Custom Buffer Tools"
        self.alias = "CustomBuffer"
        self.tools = [BufferSelectedFeatures] # Add your tool class here
class BufferSelectedFeatures(object):
    def __init__(self):
        self.label = "Buffer Selected Features"
        self.description = "Creates a 500-foot buffer around selected features."
        self.canRunInBackground = False
    def getParameterInfo(self):
        param0 = arcpy.Parameter(
            displayName="Input Feature Layer",
            name="in_features",
            datatype="GPFeatureLayer",
            parameterType="Required",
            direction="Input")
        param1 = arcpy.Parameter(
            displayName="Output Buffer Layer Name",
            name="out_buffer_name",
            datatype="GPString",
            direction="Input")
        param1.value = "Selected_Feature_Buffer" # Default name
        return [param0, param1]
    def execute(self, parameters, messages):
        in_features = parameters[0].valueAsText
        out_buffer_name = parameters[1].valueAsText
        # Set the scratch workspace for temporary data
        arcpy.env.scratchWorkspace = "in_memory"
        # Create the full path for the output buffer feature class
        out_buffer_fc = arcpy.ValidateTableName(out_buffer_name, arcpy.env.scratchWorkspace)
        # Buffer the selected features
        arcpy.Buffer_analysis(in_features, out_buffer_fc, "500 Feet")
        messages.addMessage(f"Buffer created: {out_buffer_fc}")
        # Add the buffer layer to the map (for ArcGIS Pro)
        aprx = arcpy.mp.ArcGISProject("CURRENT")
        active_map = aprx.activeMap
        # Make a feature layer from the buffered output
        arcpy.management.MakeFeatureLayer(out_buffer_fc, out_buffer_name)
        new_layer = arcpy.mp.Layer(out_buffer_name) # Create a Layer object from the temporary layer
        # Add the layer to the active map
        active_map.addLayer(new_layer)
        messages.addMessage(f"Buffer layer '{out_buffer_name}' added to the map.")
        return
-Brandon
HaydenWelch
MVP Regular Contributor
mp.Layer is a class that you can't initialize. It's a representation of a program object. You can use it to type hint a return value, but if you want to create a layer, you need to use MakeFeatureLayer and assign the result to a variable.
import arcpy
class Toolbox:
    def __init__(self):
    def __init__(self):
        in_features = arcpy.Parameter(
            name="in_features",
            direction="Input")
        out_buffer_name = arcpy.Parameter(
            direction="Input")
        out_buffer_name.value = "Selected_Feature_Buffer" # Default name
        return [in_features, out_buffer_name]
    def execute(self, parameters: list[arcpy.Parameter], messages):
        params = {p.name: p for p in parameters}
        in_features = params['in_features'].value
        out_buffer_name = params['out_buffer_name'].value
        with arcpy.EnvManager(workspace='memory'):
            out_buffer_fc = arcpy.ValidateTableName(out_buffer_name)
            arcpy.analysis.Buffer(in_features, out_buffer_fc, "500 Feet")
            new_layer = arcpy.management.MakeFeatureLayer(out_buffer_fc, out_buffer_name)[0]
            arcpy.AddMessage(f"Buffer created: {out_buffer_fc}")
        aprx.activeMap.addLayer(new_layer)
        arcpy.AddMessage(f"Buffer layer '{out_buffer_name}' added to the map.")
Just a sidenote: with the workspace set to memory, the buffer layer will exist only in memory. You can accept a full derived layer path as a Parameter input if that's what you really want to do.
DanPatterson
MVP Esteemed Contributor
and what would the error be?
... sort of retired...
TylerT
Hi @BrandonPrice1,
in-memory
 is legacy workspace.  You might try memory depending on your ArcGIS version.
See memory docs here: https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/basics/the-in-memory-workspace....
Tyler
BrandonPrice1
My apologies. Below is the error message. I tried changing in_memory to memory and got this same error.
HaydenWelch
import arcpy
class Toolbox:
    def __init__(self):
    def __init__(self):
            name="in_features",
            direction="Input")
            direction="Input")
BrandonPrice1
Thanks again, this buffer tool intended to be used as a geoprocessing service. So, the newly generated buffer layer would be added to a webmap rather than a ArcGIS Pro Project. I will try using your sample and tweak it for online use.
BrandonPrice1
Thanks. I appreciate it.
