I am in the process of converting a python script into a python toolbox. The input for my toolbox is either one or more personal geodatabases. Data from these geodatabases is then appended to an Oracle database. The question I have is I am unsure what data type I am suppose to use for my input. I have not seen anything that jumps out at me as the correct data type to use for selecting geodatabases. The only one that I thought might be correct is the 'Database Connection' data type.
Could someone please clarify which data type I should be selecting for this input parameter?
Thanks in advance for any help.
Ben.
Solved! Go to Solution.
Use a Workspace datatype - DEWorkspace
You can limit the Workspace types allowed with a parameter filter.
Something like:
def getParameterInfo(self): param0 = arcpy.Parameter( displayName="Input GDB", name="in_gdb", datatype="DEWorkspace", parameterType="Required", direction="Input") param0.filter.type = "Workspace" param0.filter.list = ["Local Database"] return [param0, other params etc...]
Something like:
