Python script to Compact geodatabases in multiple directories?
5688
01-07-2015 12:00 PM
JasonDowdy
I am trying to write a python script to walk through all folders in my workspace and find and compact all geodatabases in my workspace. I am using the 10.2.2 release.
import acrpy, os
from arcpy import env
arcpy.env.workspace "C:"
for (path, dirs, files) in os.walk(arcpy.env.workspace)
    for file in files if ".gdb" in file:
        workspaces = arcpy.ListWorkspaces("*", "FileGDB")
        for workspace in workspaces:
            arcpy.Compact_management(workspace)
JakeSkinner
Esri Esteemed Contributor
Hi Jason,
You can use the arcpy.da.Walk function to walk through the directories and then compact each geodatabase.  Here is an example:
import arcpy, os
workspace = r"C:\temp\python"
for dirpath, dirnames, filenames in arcpy.da.Walk(workspace, datatype="Container"):
    for dirname in dirnames:
        if ".gdb" in dirname:
            arcpy.Compact_management(os.path.join(dirpath, dirname))
            print "Successfully compacted " + dirname
JakeSkinner
Hi Jason,
import arcpy, os
JasonDowdy
Works great, I did finally get the other method working but this is much better than what I was trying to do.  Much appreciated!
