Python script file not encoded correctly with ANSI or utf8
11684
7
01-29-2019 09:59 AM
JoeBorgione
We've been struggling to get a python script running that originally came from ESRI: it's a maintenance script for a vector tile basemaps.  The script hasn't worked for us and the subject line above is the response we got from ESRI tech support.
Below are identical lines of code:  Line one is what we see in IDLE while Line 2 is what we see in Spyder.
tpk =  r'‪C:\Users\jaburton\Documents\ArcGIS\Projects\VectorBasemap\VectorTilePackage.vtpk
tpk =  r'‪C:\Users\jaburton\Documents\ArcGIS\Projects\VectorBasemap\VectorTilePackage.vtpk'
When we run it as a stand-alone script in Spyder it bails out with this error:
So its' not seeing the path where the variable tpk points to. The source of the raw text string is a copy and paste from a Windows Explorer window: pretty standard practice.
How do we convince Spyder all is good?
That should just about do it....
DanPatterson_Retired
# -*- coding: utf-8 -*-
at the very top of all scripts
JoeBorgione
awesome.  Thanks!
edited moments later:
Dan- it already appears at the top of the script; Spyder does it for you...
One of the 2 to 3 things you need to remember... strings are no more... strings are now Unicode and way more character sets are now supported.
JoeBorgione
Just ran it again with # -*- coding: utf-8 -*- as line 1.  Errors out with the same problem....
even worse... you didn't raw encode or use forward slashes..
Our class motto, when it comes to file paths
"C:\Users\Is\For\Losers"
File "<ipython-input-1-d259788efdf0>", line 1
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated \UXXXXXXXX escape
Don't use 'Users'
JoeBorgione
It's working now, not sure what the hicup was....
Luke_Pinner
MVP Regular Contributor
Quick hack to strip out any non-ascii characters:
input = 'C:/temp/test.py'
output = 'C:/temp/test_edited.py'
input = open(input).read()
with open(output, 'w') as outf:
    outf.write(input.encode('ascii', 'ignore').decode())
print(repr(input))
print(repr(open(output).read()))
Output:
"tpk =  r'‪C:\\Users\\jaburton\\Documents\\ArcGIS\\Projects\\VectorBasemap\\VectorTilePackage.vtpk'\n"
"tpk =  r'C:\\Users\\jaburton\\Documents\\ArcGIS\\Projects\\VectorBasemap\\VectorTilePackage.vtpk'\n"
