Python question -- List
3274
8
08-03-2022 07:33 AM
YinghongLi1
I created a list variable and assigned another variable to it.  Then i modified the 2nd by adding a new item to it.  I found out the 1st variable changed too.  Just want to confirm that assignment does not create a new list.
list1=["v1", "v2"," v3"]
list2=list1
list2.insert[0, "id"]
so list2 output is: ["id", "v1", "v2"," v3"]
however list1 output is the same.
So i can't use assignment to create a new list from list1.  rather i need to do this:
list2=["id", "v1", "v2"," v3"]
i'd like to understand this better but i did not anything by searching online.  Help please.  Thanks.
2 Solutions
JoshuaBixby
MVP Esteemed Contributor
UPDATE:  I misread the original question, so the OP is seeing the expected behavior.
If you want to make a copy of a list, there are numerous ways.  One common way is to use a list comprehension:
Type "help", "copyright", "credits" or "license" for more information.
>>> list2 = [i for i in list1]
>>> list2.insert(0, "id")
>>> list1
['v1', 'v2', ' v3']
>>> list2
['id', 'v1', 'v2', ' v3']
Another way is to use copy — Shallow and deep copy operations — Python 3.10.6 documentation
Python 3.7.11 [MSC v.1927 64 bit (AMD64)] :: Anaconda, Inc. on win32
>>> import copy
>>> list2 = copy.copy(list1)
>>> list1
['v1', 'v2', ' v3']
>>> list2
Dan_Brumm
list1 = ["v1", "v2"," v3"]
list2 = list1.copy()
print(list1)
print(list2)
['v1', 'v2', ' v3']
Daniel Brumm
GIS Nerd
JoshuaBixby
For starters, you have some invalid code so I am not sure how you are testing.  For example,
  File "<stdin>", line 1, in <module>
TypeError: 'builtin_function_or_method' object is not subscriptable
Changing the code to proper syntax, I get the expected results in Python 3.7.11 bundled with ArcGIS Pro 2.9.x
>>> list2=list1
>>> list1
>>> list2
JoshuaBixby
>>> list1
['v1', 'v2', ' v3']
>>> list2
>>> import copy
>>> list1
['v1', 'v2', ' v3']
>>> list2
Luke_Pinner
MVP Regular Contributor
list2 = list1[:] also works.
Dan_Brumm
print(list1)
print(list2)
['v1', 'v2', ' v3']
Daniel Brumm
GIS Nerd
JoshuaBixby
Nice catch, I forgot that lists had a copy method because I never use it.  list.copy() is a shallow copy like when using copy.copy(), but it is definitely cleaner.
I_AM_ERROR
Just to add context, assigning a new variable to an existing object is just creating an additional pointer to your existing list. The list already exists in memory, you just have two name for it now instead of one.
You can check by using id(var) and id(var2) for example. They'll point to the same memory address if you do something like:
var = "test"
var2 = var
JoshuaBixby
The situation is more nuanced because immutable and mutable Python objects are handled differently.  For strings, which are immutable, var and var2 don't reference the same memory once either variable is updated while that isn't the case for lists that are mutable.
>>> var = "test"
>>> id(var)
1966892852656
>>> var2 = var
>>> id(var2)
1966892852656
>>> var2 = "hello"
>>> id(var2)
1966901122480
>>> var
'test'
>>> var2
'hello'
>>> list1 = ["v1", "v2", "v3"]
>>> id(list1)
1966862258632
>>> list2 = list1
>>> id(list2)
1966862258632
>>> id(list2)
1966862258632
>>> list1
['id', 'v1', 'v2', 'v3']
>>> list2
I_AM_ERROR
Was not aware of this, thanks!
