PYTHON: My layer appears 3 times in my legend. Can't change it with arcpy but Idon't know why...
1024
11-19-2025 07:06 AM
magdatopa_ratp
Hi everyone,
I developed a Python script to automate the generation of maps in ArcGIS Pro based on various parameters.
In my layout, I want to be able to modify the LEGEND_Item, but all my attempts have failed so far...
In fact, in my legend, I only want one layer to appear, while the others should be hidden (in the legend only).
My code does allow me to hide the layers I don’t want in the legend, but the one I do want appears 3 times in the legend. I should mention that it is inserted only once in the map. Its symbology is based on unique values, and there are 3 unique values. I suspect this is related.
Here's my code and the result:
try:
legend = "LEGENDE_" + NOMCARTE
lyt_legend = lyt.listElements("LEGEND_ELEMENT", legend)[0]
lyt_legend.title = "" # Met le titre à vide
logging.info("Titre de la légende effacé.")
except IndexError:
logging.error(f"Légende introuvable dans le layout : {legend_name}")
except Exception as e:
logging.error(f"Erreur inattendue : {str(e)}")
try:
couches_a_masquer = [DEPT_lyr.name, COMM_lyr.name, DEPT_mask_lyr.name, "COMMUNES_TRONCONS_SpatJoin"]
for item in lyt_legend.items:
if item.name in couches_a_masquer:
item.visible = False
logging.info(f"Élément de légende masqué : {item.name}")
except IndexError:
logging.error(f"Légende introuvable dans le layout : {legend}")
logging.error(f"Erreur inattendue lors de la mise à jour de la légende : {str(e)}")
Also want to get rid of the label "EVOL" and change the text for each value (ex. 0 should be replaced by "Unchanged value".
Any idea on how to do it if possible?
Thanks in advance
TonyAlmeida
MVP Regular Contributor
Your symbology is unique values, so the legend automatically lists each unique value as a separate legend item. Try changing the labels for each unique value (0 → "Unchanged value", etc.), showHeading = False - Hides the layer name ("EVOL" in your case).
magdatopa_ratp
Hi @TonyAlmeida
Thank you for answering so fast.
That exactly what I suspected : the legend displays each unique value as a separate legend item.
I'll try changing the labels for each unique value but once it is done, do you know if  there is  a way to get a result that looks like that? (just one item displayed in the legend)
TonyAlmeida
I don't have an answer, I don't really like working with legends and python, there a pain in my opinion.
I am sure someone will have an idea.
