I am trying to create a python label expression without having any python skills
I have 2 fields [FIELD1] and [FIELD2]
If [FIELD1] > 0 and [FIELD2] < 0
return "text:" [FIELD1] 'text:" [FIELD2]
return 'text:" [FIELD2]
Any help would be greatly appreciated.
You could also define label classes based on those if statements, and then label each class accordingly.
Please refer to this help page as a start for building label expressions, and this post for posting code blocks.
| Header 1 | Header 2 |
If [FIELD1] > 0 and [FIELD2] < 0 return "text:" [FIELD1] 'text:" [FIELD2] | if (!FIELD1! > 0) and (!FIELD2! < 0): out = str(!FIELD1!) + str(!FIELD2!)
If [FIELD1] > 0 and [FIELD2] !< 0return "text:" [FIELD1] | elif (!FIELD1! > 0) and (!FIELD2! != 0):out = str(!FIELD1!) |
If [FIELD1] !> 0 and [FIELD2] < 0return 'text:" [FIELD2] | elif (!FIELD1! > 0) and (!FIELD2! != 0):out = str(!FIELD1!) |
else out = "no match' | |
| return out |
Lets break this down into parts
Toggle on the Python parser, in the field calculator. The results must be put into a text field.
So as python code it becomes with 4 spaces for indents.
def check_cond(a,b):
"""two fields as input, """
if a > 0) and b < 0):
out = str(!FIELD1!)
out = str(a)
else
out = "no match'
Expression box
check_cond(!FIELD1!,!FIELD2!)
Always check the unexpected, never return prematurely, hence return out should be the last line
Just a note that this is a field calculator expression, not label expression, which is quite different. Of course, you could calculate the label to a new field, but that's an added step.
There are a few tricky little things, so here goes. I don't believe there is such thing as !<, use >= instead. You can't concatenate numbers to strings, cast to string using str(). You'll have to decide if you really mean "if, if, if" or "if, elif, elif" - either can be used if you know what it means.
def FindLabel ( [Field1] , [Field2] ): if [Field1] > 0 and [Field2] < 0: return "text: " + str( [Field1] )+ " text: " + str( [Field2] ) if [Field1] > 0 and [Field2] >= 0: text = "text: " + str([Field1] ) return text if [Field1] <= 0 and [Field2] < 0: return "text: " + str( [Field2] )
I went with the various label classes. Thanks for all the info though.
I'm glad you found a solution that worked for you, Scott. Do you mind marking this questions as answered? This accomplishes a couple of things: people will realize that you don't still need help, and also, other people in the future with the same question can find the answer easier. Thanks!
I'm a moderator and marked your suggestion correct.
