Python Geoprocessing syntax from ArcGIS Pro 2.x to 3.x
1961
09-20-2023 06:13 PM
MarkChilcott
As we migrate from ArcGIS Pro 2.x to ArcGIS Pro 3.x, we a looking at Python Code.
I note in Pro 2.x the syntax in the documentation code samples for say Clip Analysis in the code samples is
                arcpy.Clip_analysis
Yet in pro 3.x it has switched to
                arcpy.analysis.Clip
Can anyone advise when this changed?
Do both work in Pro 3.x?
With the new syntax, I note my PyCharm code intelligence is now stuffed as well.  I think this is because the code document has not been changed.  ie this is in the analysis.py file in ArcPy
# Extract toolset
@gptooldoc('Clip_analysis', None)
def Clip(in_features=None, clip_features=None, out_feature_class=None, cluster_tolerance=None):
    """Clip_analysis(in_features, clip_features, out_feature_class, {cluster_tolerance})
Cheers,
Mark
JohannesLindner
arcpy.analysis.Clip is the native Python function call, i.e. Clip is a function in the module analysis from the site package arcpy, it can be found in the file "Path://to/ArcGIS/ArcPy/arcpy/analysis.py"
arcpy.Clip_analysis is the syntax you can use after you import a toolbox using ImportToolbox, which arcpy does automatically for the system tools.
Both work in ArcMap and ArcGIS Pro.
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
