Python error question
14040
34
01-22-2015 04:33 PM
DEAF_PROBERT_68
Honored Contributor
I am a beginner and just starting to learn how to use Python I learned from Python Scripting for Map  Automation.
My question to you is that whenever I get an error I see the word Traceback or errors in highlight red in my python window.
My question to you is do I need to have a pythonWin installed ? My computer at work does not have it but I use the python  Window inside ArcMap.
Are there site that can I read or learn about the Traceback error ? I am sure there are bunch of question that Traceback has in it.
So what does Traceback means and what does it do ?
DEAF_PROBERT_68
Honored Contributor
I put that damn r into what you suggest and it worked ...
Is the "r" stand for reclusive , correct ?
XanderBakker
Esri Esteemed Contributor
Glad it worked. The r is for "Raw String Notation":
https://docs.python.org/3.3/library/re.html#raw-string-notation  (sorry 3.3 docs)https://docs.python.org/3.3/library/re.html#raw-string-notation
If you copy and paste a path in python code it will probably be invalid since you have to use double backward slashed, forwards slashes or the r in front of the string holding the path. Normally the last option is the easiest,
DEAF_PROBERT_68
Honored Contributor
Are you saying that when I copy and paste the code into python window in ArcMap  does it give you an errors ?
So that means do I have to re-type them ?
DEAF_PROBERT_68
Honored Contributor
Earlier I mention that it worked.. That was all about the file geodatabase. Now I have one shapefile in the same mxd that did not  replace to the new workspace.
>>> mxd = arcpy.mapping.MapDocument("CURRENT")
>>> path = "E:\ned10DEM\Contours"
>>> mxd.replaceWorkspaces(r"\E:\FY2011_projects\10mNED\Contours","SHAPEFILE_WORKSPACE", path + r"\","SHAPEFILE_WORKSPACE")
I still got an error here : Parsing error SyntaxError: invalid syntax (line 1)
XanderBakker
I think it should be:
path = r"E:\ned10DEM\Contours"
mxd.replaceWorkspaces(r"E:\FY2011_projects\10mNED\Contours","SHAPEFILE_WORKSPACE", path,"SHAPEFILE_WORKSPACE")
each time you specify a path (as string) place the r in front of it.
DEAF_PROBERT_68
Honored Contributor
What are you using to run this code ? PyScripter ?  BTW Thanks.
XanderBakker
I didn't run the code, but when I do I use PyScripter.
DEAF_PROBERT_68
Honored Contributor
Using Python Windows within ArcMap.  I think I need to try and use PyScripter. I have to ask my IT Specialist for permission to use it on my computer.
Thanks.
XanderBakker
If I'm correct you can download the ZIP which does not need an installation...
Downloads - pyscripter - An open-source Python Integrated Development Environment (IDE) - Google Pro...
zip file for registry free installation
BlakeTerhune
It installs with a different shortcut for each Python version. Do we need to make sure we are running the PyScripter for Python 2.7 so it's "compatible" with ArcGIS? I seem to remember something about this being the case.
