Python code Module
1515
05-06-2014 06:28 AM
ChrisSlinko
I'm currently running ArcMap basis 10.2.0. in the pervious version 10.1 I was able to download an external module that could run python code.  In that module you were able to show line numbers which greatly help when you are learning coding.  It was locate on C:\Python27\ArcGIS10.1\lib\site-packages.  It was an .exe and the desk top module was a snake. I can't seem to find it when I go to C:\Python27\ArcGIS10.1\lib\site-packages.  does anyone know if it is still available if yes how to download it.  Thanks, chris
JoshuaChisholm
Hello Chris,
There are plenty of python editors. IDLE can not display line numbers (yet). Some work arounds here.
You're probably looking for "Pythonwin". There is some help for installed Pythonwin to ArcGIS here. You can also download it online here, but you'd have to be very careful not to mess up your arcpy install.
JamesCrandall
PythonWin gives you row and column numbers of the cursor postion down at the lower right corner of the app window.
Zeke
Honored Contributor
Other options include PyScripter (my favorite), Notepad ++, ConText, etc.
markdenil
besodes reporting the line number in the status bar,
IDLE also has a GoTo Line command: press Atl+G
