python beginner needs instant help calculating field
11909
21
12-02-2015 01:04 PM
AMiller
Hi, I haven't yet learned how to use python, I know a tiny bit. I am using ArcMAp 10.2. I want to use a python program to Calculate a filed as a sequential ID, as I found instructions for in "Help" under calculate field examples (Accumulative and sequential calculations).
I am at a loss as to how to enter the info properly in the calculate field dialogue boxes. I have tried a few times, not at all sure where my basic problem lies. I need to do this real fast, but I just get lost or nowhere. Can you give my python future a quick boost? What do I type in the code block? what do I type in the other area? how do I have to alter the code for my scenario (from as it is typed in the help example?)
What type of field can I use for my new ID? I created a text field, is that ok?
AMiller
Yes, thank you.
AMiller
Thanks everyone, I was just on phone with ESRI tech support, I was having some kind of issue with my existing document, the directions sent by Joe Borgione worked when I (we) tried doing in a new document.
Problem solved!! Yay!! ☺
ChrisSmith7
Honored Contributor
If you're having trouble auto-incrementing using Python, you can easily field calculate the FID or ObjectID field into your named ID field... if you need it to start at 1, just add 1 to your result, e.g. [FID] + 1
DarrenWiens2
Of course, provided no FIDs are missing.
AMiller
ChrisSmith7
Honored Contributor
Should be ok if they are calculating a shapefile field - as I understand, these are renumbered from 0 - no gaps will show-up. Of course, not the same for geodatabase!
AMiller
AMiller
DavidAllen
Here's a little inside info that can benefit everyone wanting to do calculations in the field calculator using Python. The book "GIS Tutorial for Python Scripting" has a chapter on this ... AND YOU CAN GET THAT CHAPTER FOR FREE!
Go to this Esri Press site and click "Sample Chapter":
Esri Press | GIS Tutorial for Python Scripting
You can get the data necessary to do all the work for this book at this site and click under "Resources":
Esri Press Book Resources | GIS Tutorial for Python® Scripting
That'll get you started with Python - then you can buy the rest of the book later. By the time you finish all those tutorials and exercises you should be asking for a raise!
David W. Allen
KathleenWallis
Although this document is a little dated, keep it in your files. You will find that you refer to it often.
Katy
