Python and Geocoding
3486
11
10-08-2012 07:25 AM
JayKappy
I have a stand alone table in SQL server.  I want to create a Python script to Geocode that table.
Can I set up a Geocoder to process that table and place XY coordinates into an XY Field in the table?
It has to process address and intersections.
I would have three fields House Number, Street, Intersecting Street
Any thoughts, examples on how to get started?
Do I create an mxd with the table in it and save it.
Then write soem python script to point to that mxd and process the Geocode?
JayKappy
This is what I was trying to explain.
SO it seems that I would have to create a temp table
The Table to Geocode is a Standalone SQL Server table (not SDE)
This would create a Feature Class as output once Geocoded.
Then take the FC and join back to the Standalone SQL Server table to append the XY corrdinates.
Thanks for your thoughts and input.
BradShore1
You could make an OLEDB connection to the SQL Server and geocode off of that. Then use the add XY Coordinates tool to get the XY Coordinate you want.
