Python and Field Calculator
1851
06-18-2014 12:04 PM
LeonKincy
I am trying to run the following Python script through Field Calculator
Parser:
Python
Expression:
calctemp(!Value!)
Code Block
def calctemp(newValue):
if newValue > 0:
   tempF = (newValue - 273.15)* 1.8000 + 32.00
return tempF
I get a syntax error invalid syntax(<expression>, line 1)
Any suggestions
MathewCoyle
Honored Contributor
Make sure it is indented properly.
Pre-Logic Script Code:
  if newValue > 0:
    return tempF
LeonKincy
I adjusted the indentations, but the error message persists.
Zeke
Honored Contributor
Maybe null (None in Python) values in your Value field?  Try changing the if statement to: if newValue is not None and newValue > 0:  return...etcAnother possibility: is Value a text field?These don't seem like syntax errors to me, but worth a shot. Maybe also check if Value is the real field name, and not an alias. Again not an expected error, but hey...
LeonKincy
I still have the error. I uploaded a portion of the data file. Value is long. There is one
thing I'm not sure about. Value and newValue are suppose to be interchangeable.
Value is external to calctemp and is used in the call to calctemp. While newValue is
used internally by calctemp.
