Project Trasformation for a list of shp don't work
1165
01-09-2014 01:40 AM
francescodi_vito
hello guys.
I wrote this script that should read a list of shp file from a folder and then define the spatial and then the project.
How do I create db before, and in one of these I'm going to put the result.
The model works but does not run the project.
Can you help? I do not understand why is not working
This is my script
import arcpy, os
from arcpy import env
# Envirement Settings
arcpy.env.workspace = arcpy.GetParameterAsText(0)
# Variabili per la funzione di CreateFileGDB
out_folder_gdb = arcpy.GetParameterAsText(1)
name_gdb = arcpy.GetParameterAsText(2)
out_folder_gdb_utm = arcpy.GetParameterAsText(3)
name_gdb_utm = arcpy.GetParameterAsText(4)
# Creazione dei DB
arcpy.CreateFileGDB_management(out_folder_gdb, name_gdb)
arcpy.CreateFileGDB_management(out_folder_gdb_utm, name_gdb_utm)
# Imposto lista elementi
fcs = arcpy.ListFeatureClasses('*')
imposto variabile locale
try:
    for f in fcs:
        inData = f
        coordinateSystems = "PROJCS['Monte_Mario_Rome_Italy_1',GEOGCS['GCS_Monte_Mario_Rome',DATUM['D_Monte_Mario',SPHEROID['International_1924',6378388.0,297.0]],PRIMEM['Rome',12.45233333333333],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',1500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-3.45233333],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]"
        arcpy.DefineProjection_management(inData, coordinateSystems)
        arcpy.Project_management(inData,out_folder_gdb + "/" + name_gdb + ".gdb", "WGS 1984 UTM Zone 32N","", "Monte_Mario_To_WGS_1984_4")
except arcpy.ExecuteError:
    print(arcpy.GetMessages(2))
except Exception as ex:
    print(ex.args[0])
thank you very much
greetings
JakeSkinner
Esri Esteemed Contributor
Hi Francesco,
It doesn't look like you are specifying name for the output feature class in the Project tool.  Also, you have a parameter commented out in the Project tool.  Try the following:
try:
    for f in fcs:
        inData = f
        coordinateSystems = arcpy.SpatialReference(26591)
        output = out_folder_gdb + "\\" + name_gdb + ".gdb" + "\\" + inData.split(".")[0]
        coordinateSystems = arcpy.SpatialReference(32632)
        arcpy.Project_management(inData, output, coordinateSystems,"Monte_Mario_Rome_To_Monte_Mario + Monte_Mario_To_WGS_1984_4")
Note:  I used arcpy.SpatialReference and the coordinate system code to shorten the amount of text.
