Problems with Frequency analysis
2526
03-19-2013 07:57 AM
TaylorRose
I keep getting the attached error when i try to run my frequency analysis script, any ideas why /how to fix it?
curtvprice
If the output already exists, it may help to delete the output first, change the name of your output file, or add a line of code to your script to allow overwrites of existing datasets:
arcpy.env.overwriteOutput = True
TaylorRose
Is that the source of the error because i thought it had something to do with the invalid parameter, but i havent changed anything and the script has been working fine for me for a while, i did just update to 10.1
curtvprice
There has been a major change in how database connections are handled. I'd look into that:
ArcGIS 10.1 Help: What's new for geodatabases in ArcGIS 10.1
TaylorRose
Ok i added the permission to overwrite databases but now i get the attached error, for some reason i cant create a database connection, which i am assuming has something to do with the update. Any clue on how to fix it?
curtvprice
It looks like you may not have write access to your geodatabase, or at least that part of it. To check this, connect to it manually in ArcCatalog and try to create a table there. Do you have to write your output to the ArcSDE database -- if all you want is a result you could write it to a local location.
