Problems with arcpy findAndReplaceWorkspacePath?
2399
11-11-2020 11:26 PM
JohannesBierer
Hello,
I can't find and replace a workspace path with the following script:
# -*- coding: cp1252 -*-
import arcpy, os
arcpy.env.overwriteOutput = True
mxd=arcpy.mapping.MapDocument(r"C:\temp_replaceDatasource\Detail.mxd")
class ReplaceDataSource(object):
    def __init__(self):
        self.mxd = mxd
    def DataSourcesReplace(self):
        for lyr in arcpy.mapping.ListLayers(self.mxd, ""):
            if lyr.isServiceLayer == 1:
                print lyr.name + " is a WMS Layer"
            else:
                print lyr.name + " X " + lyr.dataSource
                newDataSource = lyr.dataSource.replace("R:\\", "\\\\{}\\{}\\".format("Client", "R$"))
                print newDataSource
                lyr.findAndReplaceWorkspacePath(lyr.dataSource, newDataSource)
                print lyr.dataSource
        mxd.saveACopy(r"C:\temp_replaceDatasource\Detail_WIBAS.mxd")
if __name__ == '__main__':
    MyClass = ReplaceDataSource()
    MyClass.DataSourcesReplace()
The print statement looks ok but the path is not replaced - nothing happens with the path? Any ideas why?
output of the print statement
Maßnahmenflaeche X R:\SG-A\Karto\Bierer2020\Wiedemann_Erlen_Metten_Gründelbachniederung_Auftragskarte\Bearbeitung.gdb\data\Massnahme
\\Client\R$\SG-A\Karto\Bierer2020\Wiedemann_Erlen_Metten_Gründelbachniederung_Auftragskarte\Bearbeitung.gdb\data\Massnahme
DanPatterson
MVP Esteemed Contributor
You are using arcmap 10.4.... there are lots of bugs noted on the tech support site, that you may want to look at  for example
Bug BUG-000096779
Problem: Attempts to find and replace multiple data sources from enterprise geodatabase connections ...
but there are more
findAndReplaceWorkspacePath issues ... sort newest to oldest
... sort of retired...
Tags (1)
DavidPike
MVP Notable Contributor
Maybe lyr.save()
JohannesBierer
Thank you David,
unfortunately I get an error message if I insert lyr.save() after the findAndReplace ... :
line 35, in DataSourcesReplace
lyr.save()
File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\utils.py", line 182, in fn_
return fn(*args, **kw)
File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\arcobjects\mixins.py", line 416, in save
assert hasattr(self, '_lyr'), gp.getIDMessage(89003, "No filename set.")
AssertionError: No filename set.
DanPatterson
Bug BUG-000096779
but there are more
Tags (1)
