Problem with python script: can only concatenate list (not "str") to list
7705
8
11-08-2017 04:13 AM
JohannesBierer
I've got a problem with the following script:
import arcpy, os
infile = r"C:\temp4\ALK_Merge.shp"
infileL = "infile_Layer"
count = int(arcpy.GetCount_management(infile).getOutput(0))
x = 99
xC = count/x
xC1 = xC + 2
for i in range(1, xC1):
    print i
    sPath = infile.split(".shp")
    print sPath
    xRange = i * 99
    xRange1 = (i*99)-99
    print xRange
    print xRange1
    outFeature = sPath + "_" + i + ".shp"
    arcpy.MakeFeatureLayer_management (infile, infileL)
    arcpy.SelectLayerByAttribute_management (infileL, "NEW_SELECTION", "\"FID\" <= " + xRange + "AND" + "\"FID\" >= "+ xRange1 + "")
    arcpy.CopyFeatures_management(infileL, outFeature)
The problem is in line 25:
TypeError: can only concatenate list (not "str") to list
Any ideas how to solve this?
XanderBakker
Esri Esteemed Contributor
The method you are using to create the chunks to get exactly 99 features will only work in case there were no deletes in the featureclass.
Take the following example:
def main():
    import arcpy
    fc = r'C:\GeoNet\ArcadeMedellin\ArcadeMedellin.gdb\Solicitudes'
    oids = [r[0] for r in arcpy.da.SearchCursor(fc, ('OID@'))]
    print "FID 99 is at index:", oids.index(99)
    cnt = 0
    for lst in chunks(oids, 99):
        cnt += 1
        print "\nChunk {0} has {1} elements".format(cnt, len(lst))
        print " - OID from {0} to {1}".format(min(lst), max(lst))
def chunks(l, n):
    """Yield successive n-sized chunks from l."""
    for i in range(0, len(l), n):
        yield l[i:i + n]
if __name__ == '__main__':
    main()
this will yield:
FID 99 is at index: 92
Chunk 1 has 99 elements
 - OID from 1 to 105
Chunk 2 has 99 elements
 - OID from 106 to 211
Chunk 3 has 36 elements
 - OID from 212 to 250
The OID are not continuous, so the chunk function provides a more stable way of creating the appropriate chucks of 99 elements.
XanderBakker
When yo do sPath = infile.split(".shp") on line 16 he variable sPath will be a list and can't be concatenated with a string. However there are more things going on in your code. I will post an alternative later.
JohannesBierer
Because I want to tile the "bigger" shape into "shapes" with exactly 99 features and therefore need to give different names for the output feature class.
XanderBakker
try this:
def main():
    import arcpy
    import os
    arcpy.env.overwriteOutput = True
    x = 99
    xC = count/x
    xC1 = xC + 2
        print i
        # this will cut off the extension .shp
        fc_pathname = os.path.splitext(infile)[0]
        xRange = i * 99
        xRange1 = (i*99)-99
        print xRange
        print xRange1
        # this will create the file path to the output shapefile
        fc_pathname = "{0}_{1}.shp".format(fc_pathname, i)
        # this will define the where clause
        where = "FID >= {0} AND FID <= {1}".format(xRange1, xRange)
        arcpy.SelectLayerByAttribute_management (infileL, "NEW_SELECTION", where)
    main()
XanderBakker
def main():
    import arcpy
    cnt = 0
        cnt += 1
def chunks(l, n):
        yield l[i:i + n]
    main()
this will yield:
 - OID from 1 to 105
JoshuaBixby
MVP Esteemed Contributor
Not that it will perform any better, I haven't tested, but native slicing and itertools.izip_longest can also be used:
import arcpy
from itertools import izip_longest
chunk_size = #
fc = #
chunk_start = slice(0, None, chunk_size)
chunk_end = slice(chunk_size - 1, None, chunk_size)
with arcpy.da.SearchCursor(fc, "OID@") as cur:
    oids = [oid for oid, in cur]
oid_chunks = izip_longest(oids[chunk_start],
                          oids[chunk_end],
                          fillvalue=oids[-1])
list(oid_chunks)
JohannesBierer
Perfect thank you !
Only a very small thing - it's not
must be:
arcpy.CopyFeatures_management(infileL,fc_pathname) I think?
XanderBakker
Very true. Good catch!
JoeBorgione
Isn't the value of i numeric as well?  That seems problematic as well.  While solidly in the rookie phase in my Python carreer, could you join spath into a string, and then concatenate it with i after casting i as a string:
spath = ''.join(infile.split(".shp"))
outfeature = spath+'_'+str(i)+'_ '".shp"
Untested: 6:00 am at the kitchen table with only one cup of coffee on board....
eta... Never mind:  Looks like Xander slipped in his repsonse while I hacking....
xander_bakker
That should just about do it....
