Problem with If , For statements
15181
27
11-23-2015 03:15 AM
KONPETROV
Hello I have created this code to run a number of viewsheds for a group of points shp Pnt1, Pnt2... and a group of  Dems, dem1, dem2 etc. For some reason I don't have any results but I don't know why. This is the code:
import arcpy, os
from arcpy import env
from arcpy.sa import *
env.workspace = arcpy.GetParameterAsText(0)
out = arcpy.GetParameterAsText(1)
fc = arcpy.ListFeatureClasses("Pnt*", "Point")
ras = arcpy.ListRasters("dem*", "GRID")
point = "Pntclip_pol1"
dem = "dempol1"
i = 1
for shp in fc:
    for raster in ras:
        if (shp == point and raster == dem):
            inRaster = raster
            inObserverFeatures = shp
            outViewshed = Viewshed(inRaster, inObserverFeatures, "")
            outViewshed.save(out + "\\" + "view" + str(i))
            i = int(i) + 1
            point = "Pntclip_pol" + str(i)
       dem = "clippol" + str(i)
KONPETROV
Because after the first pair of Point (Pntclip_pol1) and Dem (dempol1) I want to do the viewshed for Pntclip_pol2 and dempol2 etc 3,4,5..
BillChappell
Ok,
To break it down:
fclist( PntA, pntB, pntC, pntD) <<< an example list of point features
demlist (dema, demb, demc, demd) <<example list of dems…
count = 1
for i in fclist #PntA first shape in list
for rak in demlist #dema first dem in list
if i == Pnta and rak == dema
outViewshed =Viewshed(rak, i)
outViewshed.save(mypath
"view" str(count)) #view1
count = count + 1
point = Pnta + 1 # Pnta1 #last indented code, last line of if statement
dem = dema+1 #dema1
NOTE: in green Pnta1, if not found your code will bomb here, after first view is run.
Did you want to run everything in the fclist against your first dem?
Then run it all over again against your second dem?
For i in fclist
For x in demlist
Outview =viewshed(I,x)
Save it here
  1. running again will use the first i and the second x and so on
  1. next i will run through (second i) and first x in xlist, then second x in xlist, etc..
Until you finish the I list..
BillChappell
Forgot in a list (pnta, pntb, pntc)
To get the second item list[1] , you would have to remember the index or make count start at zero.
In your example you could have it just process one right after the other and not worry about the list index number..
KONPETROV
I don't think I fully understand you,
I am seeing many errors in  the code, it would be better if you could put it in Python context.
for example
outViewshed.save(mypath"view" str(count)) here it should be (mypath + "view" + str(count))
count = count + int(1)
point = Pnta + str(1)
Unfortunately my code isn't right as well I can get only one Viewshed
BillChappell
It’s your logic that’s tripping you.
• import arcpy, os
• from arcpy import env
• from arcpy.sa import *
• arcpy.env.overwriteOutput = True
• env.workspace = arcpy.GetParameterAsText(0)
• out = arcpy.GetParameterAsText(1)
• fc = arcpy.ListFeatureClasses("Pnt*", "Point")
• ras = arcpy.ListRasters("dem*", "GRID")
• point = "Pntclip_pol1"
• dem = "dempol1"
• i = 1
• for shp in fc: <<< First time in loop this is Pntclip_pol1???? 2nd time it’s Pntclip_pol2 ??
If it’s Pntclip_pol1 why did you define it?? It’s the first item in your fc list.
• for raster in ras: first time it’s dempol1?? Is that also the first item in your dem list?
• # if (shp == point and raster == dem): ???WHY??? Not needed..
• #inRaster = raster # not needed
• # inObserverFeatures = shp #not needed
• #outViewshed = Viewshed(inRaster, inObserverFeatures, "")
outViewshed = Viewshed(raster, shp)
• outViewshed.save(out + "
• i = i + 1 #already an int as declared above..
• #point = "Pntclip_pol" + str(i)
• # dem = "clippol" + str(i)
Just say you have 3 points and 5 dems
For i in pointlist:
For dem in demlist:
theViewshed = viewshed(dem, i)
the Viewshed.save (xxxxxx+ str(1))
Here the loop would use the same i and run through the next dem
Once finished it would loop the next i and toss you back into the dem loop
1 pt
1 dem
Viewshed (1 dem, 1 pt)
Now loop
2 dem
Viewshed( 2 dem, 1 pnt)
Now loop
3 dem
Viewshed( 3 dem, 1 pt)
Now loop
Etc.. until finished with dems then kick to 2nd point
2 pt
1 dem
Viewshed (1 dem, 2 pt)
Now loop
2 dem
Viewshed( 2 dem, 2 pnt)
Now loop
3 dem
Viewshed( 3 dem, 2 pt)
Now loop
You don’t need to name the items in each list as they will always advance to the next item in each list.
Leave i =1 and have I = i+1 inside the dem loop so your new views are numbered..
KONPETROV
That's a very analytic answer Mr Chappell, thank you very much.  I will study the code and I will reply you.
KONPETROV
Ok I understand you now. Well at your question,  I define point and dem because each dem has only one specific point. Dem 1 has only point 1, dem2 has only point 2 etc..
BillChappell
Oops, I screwed up , change my working script to:
fcList = arcpy.ListFeatureClasses("Pnt*", "Point")
#rasList = ras = arcpy.ListRasters("*", "All")
ras = “dem”
i = 1
for fc in fcList:
ras = ras + str(i)
print "Point is: " + fc + " the DEM is: " + ras
outViewshed = Viewshed(ras, fc)
outViewshed.save("C:/test/out/outvwshd"+ str(i))
ras = “dem”
i=i+1
print "Done"
Sorry I messed up I do a lot of point intersects with polygons, and I often step through 2 lists..
KONPETROV
I will check it out also but the previous code returned me only Pointclippol1 & Pnt1,  Pointclippol1 & Pnt2 and then again the same error.
BillChappell
This might help..
