Possible Unicode Error?  Field Calculator Help!!
2289
03-05-2014 04:39 AM
MaryM
I am getting funny symbols when I do a simple field calculate on a unicode field in a file geodatabase.
I do this:
arcpy.CalculateField_management(outFileThree, "HOTLINK", "!HOTLINK!.lower()", "PYTHON_9.3", "")
and get funny little L or upside down Ls in the field where there were \ characters or \0s.
How do I field calculate correctly field calculate and why is this happening?
MaryM
After several days of trying and finally posting and then I just figured it out...
arcpy.CalculateField_management(lyr, "TestHotlink","r!HOTLINK!.lower()", "PYTHON_9.3", "")
I kept trying things like r(!HOTLINK!) which did not work.
JoshuaChisholm
I think it's not working because python sees / as an escape character. It turns /0 into a special character (that's show up odd in your attribute table). I couldn't find an easy and functional solution.
As much as I hate to say so, the easiest fix might be to just use vb script instead of python:
arcpy.CalculateField_management(outFileThree, "HOTLINK", "LCase( [HOTLINK] )", "VB", "")
Let me know how it goes!
MaryM
