Possible to run a model and have time slider pop up automatically??
1042
04-24-2014 09:11 AM
CarolineMerz
I'm building a model and I want a time slider to pop-up automatically for a layer.  Is there anyway to call the time slider from model builder?
I found this article: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s300000023000000.....does anyone know if this works in 10.2?
curtvprice
The only possibility is if you can access the layer object using Python. This may work by using a function in the Calculate Value code block to access the mxd object as shown in the examples - or you may have to write a Python script tool and call it from your model.
It looks like some things are slightly different at 10.1/10.2, but the functionality sure looks similar. Here's the corresponding 10.2 help article:
http://resources.arcgis.com/en/help/main/10.2/index.html#//00s300000023000000
