Possible to calculate a raster's standard deviation break values?
1736
01-30-2013 06:56 AM
NickJacob
I'm trying to reclassify a raster by standard deviation using arcpy.  Problem is that when I go to use RemapRange I don't know how to calculate the break values for my new classes.  Does anybody know how to get around this?  I can access a few raster properties via GetRasterProperties_management(), but I need actual break values before I can reclassify.
arcpy.sa.Reclassify (in_raster, reclass_field, remap, {missing_values})
arcpy.sa.RemapRange (remapTable)
markdenil
GetRasterProperties_management (in_raster, "STD", {band_index})
gives you the Standard Deviation.
GetRasterProperties_management (in_raster, "MEAN", {band_index})
gives you the mean.
Similarly, MINIMUM and MAXIMUM returns the range.
The first Standard Deviation should be centered on the Mean: half above and half below.
The other breaks are full StdDev steps in each direction, to the end of the range.
markdenil
gives you the mean.
NickJacob
Thank you!  Great answer.
AndrewChapkowski
You can also use the arcpy.Raster object to get all the properties a tad faster.
Check out: http://resources.arcgis.com/en/help/main/10.1/index.html#//018z00000051000000
