polygon with holes + arcpy.AsShape is broken?
3623
10-06-2011 12:58 PM
DustinReagan
I was searching for a way to programmatically create a polygon with a hole, as there isn't any obvious way of doing this in the documentation, I started fumbling around on my own.  I came up with this test script:
gjPolygonWithHole  = {
    "type": "Polygon",
    "coordinates": [
                    [[-88.684979400000032, 38.154361399999985], [-88.666690199999962, 38.154329800000042], [-88.67131005539963, 38.154337782166039], [-88.675899944207302, 38.154345712555887], [-88.675899944207302, 38.150691003182175], [-88.67131005539963, 38.150691003182175], [-88.67131005539963, 38.147037172952786], [-88.675899944207302, 38.147037172952786], [-88.685066075460313, 38.147037172952786], [-88.684979400000032, 38.154361399999985]],
                    [[-88.680463013034853, 38.152519617763254], [-88.680463013034853, 38.15068957953018], [-88.678182297717754, 38.15068957953018], [-88.678182297717754, 38.152519617763254], [-88.680463013034853, 38.152519617763254]]]
def main():
    outputShapeDir = r"c:\temp"
    outputShapeFile = r"test.shp"
    spatialRef = r'X:\Nadel&Gussman\McLeansboro\Sections.prj'
    newFC = arcpy.CreateFeatureclass_management( outputShapeDir, outputShapeFile, "POLYGON", "", "", "", spatialRef )
    cur = arcpy.InsertCursor(newFC)
    array = arcpy.Array()
    point = arcpy.Point()
    # Create a list to store the features
    features = []
    # Read the coordinates
    for part in gjPolygonWithHole["coordinates"]:
        for coordPair in part:
            point.X = coordPair[0]
            point.Y = coordPair[1]
            array.add(point)
    feat = cur.newRow()
    feat.shape = array
    cur.insertRow( feat )
if __name__ == '__main__':
    import arcpy
    main()
Amazingly, it works (I'm not really sure how, since I don't do anything to separate the interior from the exterior, other than suddenly switch winding order):
Unfortunately, this doesn't work in all polygon-with-a-hole cases that I am working with.
So...I noticed the seemingly useful "AsShape" functionality here.  Specifically, (notice the AsShape example on doing just this at the bottom of the page i linked).
I put together a little sample script to test this:
    "type": "Polygon",
    "coordinates": [
def main():
    feat = cur.newRow()
    feat.shape = arcpy.AsShape( gjPolygonWithHole )
    import arcpy
    main()
FAILURE:
The hole is completely ignored.  Any clue as to why?
Regarding holes, I found this thread, and adapted their method to my test script + data.  It almost works:
Here's my example code:
    "type": "Polygon",
    "coordinates": [
def main():
    features = []
            array.add(point)
        null_point = arcpy.Point()
        array.add(null_point)
    feat = cur.newRow()
    feat.shape = arcpy.Polygon( array )
    import arcpy
    main()
Any ideas why this doesn't work?  Why is creating geometry such a hassle with arcpy?  Why do some methods work and some do not?
Most likely I'm missing something obvious...
Dustin
KimOllivier
Honored Contributor
The key to understanding "donuts" is that there is a  [null point] separating the nested rings list of points in each part. Not between parts.
There are some conference technical workshop presentations that set this out very well.
A polygon array in a python pseudocode list would look like this: (of course it has to be in an Arcpy array in internal binary, you cannot just pour this into the array, maybe you can with AsShape, but assembling the list as a JSON string is just as hard). Your example list does not distinguish between parts and donuts.
[[pt,pt,pt,,pt,pt,pt],[pt,pt,pt,pt]]
This is a polygon containing two separate parts, with the first part containing a hole.
You don't have to reverse the directions, ArcGIS does that for you automatically to generate a valid shape. You can have islands inside donuts and so on. Lakes can be like this, an island in the lake that has a small lake in the island.
When you assemble the part array of points and you get to the donut, just add a null point and carry on. I think of it as a 'pen down - pen up' operation that we used to program for pen plotters.
It appears that your error is to add a null point at the end of a part, rather than making the hole within the same part. Likewise adding a null point between parts would not make a donut, just a null part which would be erases by the validator.
Earlier when you reversed the coordinates, it seems that ArcObjects detected that and added in a null for you to make a donut, but I wouldn't rely on that.
# donut example
# with explicit null pair to flag a donut
# this example only has one feature and one part in the feature
# coordinate pairs are shown as tuples for clarity
# Kim Ollivier
coordList = [[
            [(-88.684979400000032, 38.154361399999985), (-88.666690199999962, 38.154329800000042),
            (-88.67131005539963, 38.154337782166039), (-88.675899944207302, 38.154345712555887),
            (-88.675899944207302, 38.150691003182175), (-88.67131005539963, 38.150691003182175),
            (-88.67131005539963, 38.147037172952786), (-88.675899944207302, 38.147037172952786),
            (-88.685066075460313, 38.147037172952786), (-88.684979400000032, 38.154361399999985),
            (-88.680463013034853, 38.152519617763254), (-88.680463013034853, 38.15068957953018),
            (-88.678182297717754, 38.15068957953018), (-88.678182297717754, 38.152519617763254),
            (-88.680463013034853, 38.152519617763254)]
def main():
  features = []
  for feature in coordList:
    print "feature", feature
    for part in feature:
        print coordPair
        if len(coordPair) == 0:
        else:
            array.add(point)
      # Create the polygon object
    polygon = arcpy.Polygon(array)
    # Clear the array for the next feature
    array.removeAll()
    # Append to the feature list
    features.append(polygon)
    # Copy the features to an output feature class
    arcpy.CopyFeatures_management(features, outputFeatureClass)
    import arcpy
    outputShapeDir = "c:/temp"
    outputShapeFile = "test.shp"
    if not arcpy.Exists(outputShapeDir+"/"+outputShapeFile):
        spatialRef = arcpy.SpatialReference(4326) #  or "GCS_WGS_1984"
        outputFeatureClass = arcpy.CreateFeatureclass_management( outputShapeDir, outputShapeFile, "POLYGON", "", "", "", spatialRef )
    else:
        outputFeatureClass = outputShapeDir+"/"+outputShapeFile
    main()
To go back the other way, see my resource example tool "Fill Donut" on the resources page.
http://resources.arcgis.com/gallery/file/Geoprocessing-Model-and-Script-Tool-Gallery/details?entryID...
I know that Esri has added a tool to do this and you can manually edit donuts, but this is a script to show how to program them.
DustinReagan
Thank you very much for the reply.
Unfortunately your script also produces incorrect (but close) results:
Additionally, your method appears to be functionally equivalent to the last method that I posted.
You say:
If you'll look closely at my code, you'll see that I only ever add a single part to "array", putting a null Point between the points that describe exterior and the points that describe the interior (all in the same part).
    features = []
            array.add(point)
    feat = cur.newRow()
Unless I am mistaken, adding multiple parts to a polygon would involve something like:
polygonArray = arcpy.Array()
partArray = arcpy.Array()
for part in coordinateList:
        partArray.add(point)
    #add the null point
    partArray.add( arcpy.Point() )
    polygonArray.add(partArray)
    partArray.removeAll()
newMultiPartPolygon = arcpy.Polygon( polygonArray )
polygonArray.removeAll()
Thanks for your time,
Dustin
