Panning to lat lon
1642
01-08-2011 12:09 PM
ScottOatley
Is there a way to center the data/layout view on a set of lat-lon coordinates?
Or is the only way to calculate an extent on the coordinates and then change the extent?
Scott
MIchalBularz
there should be a go to Xy tool in the basic toolbar.
If you have trouble saving a specific location between data an layout views you can create bookmarks on the top toolbar to save specific coordinates and viewing scales.
AndrewChapkowski
Scott,
You can use the ArcPy mapping module to zoom to extent or pan to a feature.  Here is an example:
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
df.zoomToSelectedFeatures()
arcpy.RefreshActiveView()
del mxd
This should zoom to selected features.
Here is a link to more information on zooming to features: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/DataFrame/00s300000003000000/
Enjoy
ScottOatley
Hello,
Scott,
So, ultimately, if I want to do the equivalent of say:
import arcpy
df.zoomToXY(lat, long)
del mxd
There is no equivalent of the bold statement in the code above. I have to convert my lat-long coordinates to an extent and use zoomToExtent().
Regards,
Scott
