Outputting same name as input using Copy Features
5186
11
07-08-2020 09:21 AM
AliciaShyu
I'm writing a script that has 30+ layers and a boundary layer. I need to copy all the layers that intersect with the boundary to a GDB.
I have the following for the "Select layer by location" tool
# Select by location all layers that intersect with AirBound and copy selection to GBD
= aprx.listMaps("Test")[0]
for layer in m.listLayers():
    if layer.name != AirBound:
        arcpy.SelectLayerByLocation_management (layer, "INTERSECT", AirBound)
        print (arcpy.GetMessages())
Is there any way to use "Copy Features" tool  where the output name is the same as the input name?
Thanks!
AliciaShyu
This is a monthly recurring task. So every month the old GDB will be deleted and a new one created. After the new one is created, all the layers (records in each layer) that intersect with the AirBound layer will be copied to the new GDB.
JoeBorgione
Let's follow Josh's lead from just above; his point is what I'm getting at at.
