Options for georeferencing JPG images with arcpy
1698
04-13-2022 11:21 AM
EricEagle
I am working with a library of overhead images accessible via simple REST endpoint.
The workflow I'd like to have is that a user can query this library by their current ArcGIS Pro, active map view extent.  That part works fine and I generate a series of polygon footprints onto the map.
However, there's a small overview image associated with each record that I'd like to pull in and display on the map, doing a simple 4-corner georeferencing of the overview JPG with its corresponding polygon.
However searches for georeferencing via arcpy aren't turning up a lot.  How should I go about displaying these overview images on the map?
SteveCole
Honored Contributor
I'm just thinking out loud but since you're working in ArcGIS Pro and not over the web exclusively, how about downloading a copy of the image from the REST endpoint to a given folder on the user's machine, create a world file for the JPG in the same folder, and then add the image to the map? You seem to have access to the 4 corner coordinates so I think you have enough information to work off of.  Download one of those files and then work through it manually and then automate it based on what you learn.
EricEagle
Yeah, been trying this with zero success in ArcGIS Pro.  I think I'll have to use gdal in this case, convert the jpg to a tiff, and issue the tie points in memory (ArcGIS wants a text file/csv).  More straightforward.  Thankfully since Pro's default python ships with gdal now, I can offer it to users with no dependency friction.
