Multiprocessing with ArcGIS Pro arcpy
2990
05-01-2024 09:21 AM
ckoenig77
I'm experimenting with attempting to use multiprocessing to perform some geoprocessing with a standalone Python script.  I have ArcGIS Pro 3.2.2 installed.  I'm calling this script in a command window with "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\propy".
The script will create usually around half of the feature classes without issue, but others fail randomly due to the following errors:
  • ERROR 000732: Feature Class Location: Dataset C:\Mapping\FileGDB/CIMS_CLU_Test.gdb/FeatDS does not exist or is not supported
  • ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support
  • ERROR 160193: This release of the GeoDatabase is either invalid or out of date.
  • ERROR 160706: Cannot acquire a lock.
I've experimented with decreasing / increasing the processes in the Pool declaration to no avail.  Is it realistic to expect this kind of multiprocessing to work with file GDBs or is there a trick I'm missing in the code that will help?  Thanks in advance for any suggestions you can provide.
import arcpy
from multiprocessing import Pool
path = r"C:\Mapping\FileGDB"
filename = "Test.gdb"
# Set local variables
out_path = path + "/" + filename + "/FeatDS"
geometry_type = "POLYGON"
release = "04_2024"
has_m = "DISABLED"
has_z = "DISABLED"
def createFC(state):
    try:
        arcpy.CreateFeatureclass_management(out_path, state + "_" + release, geometry_type, None, has_m, has_z)
        print(f"{ state } created")
    except Exception as e:
        print(f"{ state } error: { e }")
def work():
    states = [ 'AL', 'AR', 'AZ', 'CA', 'CO', 'DC', 'FL', 'GA', 'IA', 'ID', 'IL', 'KS', 'KY', 'LA', 'MD', 'MI', 'MN', 'MO', 'MS', 'MT', 'NC', 'ND', 'NE', 'NM', 'NV', 'NY', 'OH', 'OK', 'PA', 'SC', 'SD', 'TN', 'TX', 'UT', 'VA', 'WA', 'WI', 'WY', 'AK', 'CT', 'DE', 'HI', 'ME', 'MA', 'NH', 'NJ', 'RI', 'VT', 'WV'  ]
    with Pool(processes=4) as pool:
        pool.map(createFC, states)
        pool.join()
        pool.close()
if __name__ == '__main__':
    work()
    print('end')
Luke_Pinner
MVP Regular Contributor
The usual way is to ensure all sub-processes have their own workspace/gdbs. Your sub-processes can write their FCs to those without any locking issues from other sub-processes. Then the main process can collect all the FCs and copy them to the final output workspace.
JoshuaBixby
MVP Esteemed Contributor
With multiple processes accessing the same file geodatabase, especially to make edits, you will run into locking issues.  Might be worth reading through:  FAQ: How Are the Various Lock Mechanisms Implemented in ArcGIS Enterprise and the Geodatab (esri.com...
Luke_Pinner
ckoenig77
This makes sense thank you for your suggestion!
